当前版本的文档还未经巡查,您可以查看最新的已查核版本。
你所需要的
这个步骤还没有翻译 帮忙翻译一下
Carefully pry the motherboard assembly from the phone.
The charging port assembly is soldered to the motherboard piece. Remove the port with a soldering iron.
Once you have removed the faulty port, replace it with the new port. Attach the new charging port with the soldering iron.
After installing the new port, repeat the steps in reverse order to reassemble the phone.
即将完成!
终点
另外一个人完成了本指南。
