本指南有最近更改,您可查看未经巡查的最新版本。
你所需要的
Slide the screen up.
Remove front silver trim by using a plastic opening tools and wiggle it off.
Once you remove the rim cover, you should find two more screws on the top. Unscrew them with a T-6 screw driver.
Remove the three ribbon cables and the antenna wire by hand.
The cable in red is glued to the metal cap. Peel it upwards towards the battery compartment.
Remove the black sticker located above the logic board that contains the phone's serial number
Behind the black sticker you should find six small yellow screws. Remove them with a T4 torx screwdriver.
There is one last orange ribbon cable that needs to be pulled and behind it is the cursor
Push the cursor upwards and out of the socket.
Gently pull out the white box by pulling straight out of the socket to the right. This is your cursor
另外一个人完成了本指南。
