当前版本的文档还未经巡查,您可以查看最新的已查核版本。
Unscrew the four screws using the T6 screw driver.
If you remove the screw in red, you void the warranty!
Slide the screen up.
Remove front silver trim by using a plastic opening tools and wiggle it off.
This is difficult to remove, but it should come off if you do it with caution.
Slide the silver plate up and you should find four more screws that need to be removed. Use a T-4 screw driver.
They are on a black cover located on the bottom of the phone. The black cover will come off
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
预览
