简介
这个教程将帮助你更换黑莓 Classic 的电池。
你所需要的
这个步骤还没有翻译 帮忙翻译一下
Use extreme caution when removing the battery. It is directly against the motherboard, and piercing the battery could corrode other components. It could also catch flame.
Take off the battery shield, and use a scalpel or other flat tool to remove the foam on the connector. Place these onto new battery.
Carefully apply some low heat to the stickers covering the battery and gently peel them off. The white sticker is connected to adhesive under the battery.
Gently pry up on the edges of the battery so that the adhesive will come out more easily. Take great care not to pierce the black "skin" on the battery.
Slowly start pulling the adhesive tab out, regripping close to the battery as it starts to come out.
倒序执行这些步骤,就可以装回你的设备。记得要更换电池接口上的海绵垫。
17等其他人完成本指南。
由衷感谢以下译者:
66%
Steven Wong正在帮助我们修复这个世界! 您也想加入吗?
开始翻译 ›
8条评论
Glad it helped!
Success! Nerve racking for an amateur and I could not have done it without your guidance.
Thank you.
Ken Wright - 回复
So happy to be of help!
My BB is going to have a 2nd life. Unbelievably irresponsible to glue everything together.
Thx Jessica for this great guide. It worked perfectly and in a spell.
