跳转到主内容
BlackBerry KEYone Motherboard Disassembly
你所需要的
  1. BlackBerry KEYone Motherboard Disassembly, The BlackBerry KEYone: 步骤 1 中的图像 1,1
    • The start of our disassembly. The BlackBerry KEYone logo screen.
  2. BlackBerry KEYone Motherboard Disassembly, Remove the Sim Card Tray: 步骤 2 中的图像 1,1
    • Use a sim card removal tool to remove the sim card.
  3. BlackBerry KEYone Motherboard Disassembly, Heat the top of the phone: 步骤 3 中的图像 1,1
    • Apply heat to the top of the phone to remove the microphone plastic cover. There is a fair amount of adhesive holding this cover down.
  4. BlackBerry KEYone Motherboard Disassembly, Remove the Plastic Cover: 步骤 4 中的图像 1,1
    • Use an iSesamo or other preferred pry tool to remove the plastic cover from the BlackBerry.
    I’m going to replace one top plastic cover with my original one in mint condition (bought a replacement after i dropped it and it has a huge dent in it). After you use heat and the tool to take it off, how do you get it back on in regard to the adhesive? Thanks for any tips.
    Stanley Tam - 回复
    Could use your expertise. I’m going to replace my new plastic top cover with my original phone (the replacement i bought had a huge dent and gash in it). After I heat it and use the tool to remove the one with the dent, how do you reapply the cover? Is there still adhesive? Thank you for any tips.
    Stanley Tam - 回复
  5. BlackBerry KEYone Motherboard Disassembly, Remove two Phillips screws.: 步骤 5 中的图像 1,1
    • Remove the two Phillips screws. They may be hiding under some adhesive.
    So glad I found this tear down, I purchased a KeyOne and in the process of rebuilding. Now only need this top cover but couldn’t figure out how to remove it.
    Orlando Sanders - 回复
  6. BlackBerry KEYone Motherboard Disassembly, Slide off the Plastic Top of the Phone: 步骤 6 中的图像 1,1
    • The plastic top of the phone will slide off after removing the two screws.
  7. BlackBerry KEYone Motherboard Disassembly, Remove the Rear Plastic Battery Cover: 步骤 7 中的图像 1,1
    • With the top plastic cover off it is pretty easy to use your preferred plastic pry tool and remove the battery cover.
    Can you point out exactly where the NFC antenna is located. I see potentially two on the back cover. But, can't tell the area of the back one behind the black padding.
    Dominic Nocera - 回复
    Care needs to be taken with the plastic tabs on the rear cover, especially when reassembling. They are pretty fragile and once one is broken off, the cover will not sit flush. When reassembling, start at one of the bottom corners with that side’s tabs slipped into the bottom case. When pressing down on any of the remaining tabs, one by one, use a small flat bladed screwdriver or stout plastic prise-apart tool and carefully and gently use it to push inwards directly on the tab so it has less to ‘bend’ before it snaps into place. This may be more relevant to aftermarket rear cases where you are replacing a broken case with a non-genuine replacement.
    Steve Cottrell - 回复
  8. BlackBerry KEYone Motherboard Disassembly, Remove the Loud Speaker Cover: 步骤 8 中的图像 1,1
    • Once the back cover is off remove the 7 Phillips Screws at the bottom of the phone that are covering the loudspeaker and the part of the motheboard where the USB type-C charging port is located.
    Hello, tnx for your guidance,
    May I ask a question?! some times my blackberry keyone loud speaker stop working, and I should push on back cover to it get to work…
    Can you explain me what happened?! and is any way to repair it without changing loud speaker?!
    Gol pesar - 回复
  9. BlackBerry KEYone Motherboard Disassembly, Remove the Metal Flex Connector Bracket: 步骤 9 中的图像 1,1
    • Removing the loud speaker cover will allow you to remove the other two Phillips screws for the metal bracket that covers up a couple flex connectors.
  10. BlackBerry KEYone Motherboard Disassembly, Disconnect the Battery: 步骤 10 中的图像 1,1
    • Disconnect the two Phillips screws connecting the battery flex connector to the motherboard. Now you can remove the battery. There is ALOT of adhesive holding the battery in place. I recommend applying heat and using a plastic tool to slowly work the battery out. The volume and power flex runs under the battery. Be cautious near the top left.
  11. BlackBerry KEYone Motherboard Disassembly, Disconnect the Flex Cables: 步骤 11 中的图像 1,1
    • With the battery out disconnect the three flex cables and remove the remaining two Phillips screws from this area of the motherboard.
  12. BlackBerry KEYone Motherboard Disassembly, Remove the Black Plastic Bracket: 步骤 12 中的图像 1,1
    • There are three Phillips screws holding down a black plastic bracket that was previously partially covered by the silver bracket removed earlier. Two of the screws are visible without removing the silver top bracket but the third middle screws requires the top bracket be removed first.
  13. BlackBerry KEYone Motherboard Disassembly, Remove the Motherboard: 步骤 13 中的图像 1,1
    • With all screws and brackets removed and all flex cables disconnected you can now remove the motherboard. I recommend starting at the top (Rear facing camera side) and removing the board top down because the charging port sits in the frame of the phone and will come out more easily last.
  14. BlackBerry KEYone Motherboard Disassembly, Done!: 步骤 14 中的图像 1,1
    • All done the motherboard is out. Revealing the vibrate motor and headphone jack.
结论
22等其他人完成本指南。
团队
#TomatoBetChallenge #TomatoBetChallenge 的会员
Business
1 名成员
创作了1篇指南
20条评论
what about the screen on the front :)
Matt Howard - 回复
excellent. thanks. what about the keyboard? ;-)
joyce - 回复
Be great to have a screen replacement guide
smwduncan - 回复
Why the manufacturer always put so much adhesive on the battery??? To make it hard for people to install new ones?
johncklai - 回复
I don't think so. To prevent any form of movement.
ugbede ahiaba -
Where is the backlight ic on the board? That's the only problem with my KeyOne. Every works except the light on the screen. Under very bright light, I can manage to see and operate the phone.
ugbede ahiaba -
No need for a screen replacement guide on this phone. It automatically comes off during normal use.
polojh - 回复
i need keyboard Disassembly instruction
moekz - 回复
It’s a bummer to see so much adhesive. Nice guide though, thanks for making it!
Kim Arre - 回复
Can you circle or show on a picture where exactly is the Wi-Fi. Is it pins or a cable or chip? How can you replace or remove the Wi-Fi parts? What is the circuit leading to WiFi? Can the phone still work if the Wi-Fi part is broken off?
Eddie Valenzuela - 回复
The top cover is not plastic, it’s metal - in step 6
Ljubomir Medakovic - 回复
Mine is plastic. Quite flexible.
ugbede ahiaba -
Help. I need a working motherboard for my KeyOne. Help please.
ugbede ahiaba - 回复
“Have you seen a man skillful at his work? He will stand before kings; he will not stand before common men.”
Proverbs 22:29
“Let the one who steals steal no more; rather, let him do hard work, doing good work with his hands, so that he may have something to share with someone in need.”
Ephesians 4:28
God bless my friends!
Nathan Albertson - 回复
Ok! So I'll be replacing the front assembly complete with display next week. I hope I can stand before kings when I'm done! I figure the hardest part will be getting the battery out, any last suggestions?
Michael Winiarz -
What does that babble have to do with anything?
Yazan Sakran -
Yes. Use a hot air tool on the screen side if the phone and maybe 150° on the battery side directly (take advice at your own risk) and then use an isesamo patiently around all edges of the battery until using the pictures above you can safely remove the battery without damaging any flex cables and lift the battery out.
How broken was the original screen? If you retrace your steps and reconnect the original screen does the LCD work?
Either way I would closely examine the flex cables on your new screen and the connectors on the motherboard side.
If it was me I would order another screen. Maybe from a known reputable vendor if possible. Faulty parts are a thing especially on lesser known devices.
If you just want the data order another BlackBerry KEYone and swap the boards. Then you know for sure the LCD isn't the problem.
as far as keyboard removal, it is just slightly adhered to the housing. carefully wedge a plastic pick under the spacebar area and with a little heat, it should just come up, while using the pick to pry it up. be mindful of the flex connector that goes through the frame to attach to the board.
Steve B - 回复
Nathan - what type of heat source did you use for warming the adhesive and what temperature do you believe is safe?
Dwayne Hall - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 50
总计 31,407
