当前版本的文档还未经巡查,您可以查看最新的已查核版本。
这个步骤还没有翻译 帮忙翻译一下
With your thumb press down on the locking- button on the back of the BlackBerry 7280.
Slide the battery cover off the device.
Remove the lithium-ion battery from the back of the device using your index finger.
Hold the device with both hands.
Lift the SIM card holder using your thumb and index finger.
Remove the SIM card from the device.
Using a Torx T6 screwdriver, remove all six 1/8 inch screws (marked in red) from the back case. Set screws aside.
The SIM card has been removed here to prevent damage to the card. This is recommended, but not not required.
Use the plastic opening tool to pry the back case away from the front case.
Using a Torx T6 screwdriver, remove the lone 1/8 inch screw that holds the upper metal bracket onto the larger metal bracket. Set aside the screw and the bracket.
Remove the front plastic case from the metal bracket.
Use the plastic opening tool to pry at the edge of the screen near the track-wheel.
Use a Torx T6 screwdriver to remove the 3 1/8 inch screws shown.
Remove the logic board with your hands.
取消:我没有完成这个指南。
与4其他贡献者
于03/11/13注册
10 声望
创作了5篇指南
徽章: 7
+ 4更多徽章
CLEM-BENSON-S13S12G2
4 名成员
创作了11篇指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
过去 24 小时: 3
过去 7 天: 3
过去 30 天: 17
总计 380
