跳转到主内容
Black and Decker Pivot MAX Power Switch Replacement
你所需要的
  1. Black and Decker Pivot MAX Power Switch Replacement, Battery: 步骤 1 中的图像 1,2 Black and Decker Pivot MAX Power Switch Replacement, Battery: 步骤 1 中的图像 2,2
    • Press in and hold the release button.
    • Rotate the dust filter chamber counter-clockwise.
    • Remove the dust filter chamber.
  2. Black and Decker Pivot MAX Power Switch Replacement: 步骤 2 中的图像 1,1
    • Remove the two 10 mm screws from the motor casing with a Phillips #1 screwdriver.
  3. Black and Decker Pivot MAX Power Switch Replacement: 步骤 3 中的图像 1,1
    • Pull the battery cover up and then slide it away from the motor to remove.
  4. Black and Decker Pivot MAX Power Switch Replacement: 步骤 4 中的图像 1,1
    • Remove the battery unit by pulling it out of the main body.
  5. Black and Decker Pivot MAX Power Switch Replacement: 步骤 5 中的图像 1,1
    • Disconnect the quick connect wire harness that connects the motor and battery located in the battery storage compartment.
  6. Black and Decker Pivot MAX Power Switch Replacement, Pivot Lock Button: 步骤 6 中的图像 1,1
    • Remove the handle cover by removing the three PH1 20mm screws
  7. Black and Decker Pivot MAX Power Switch Replacement: 步骤 7 中的图像 1,1
    • Pull out the pivot lock button.
  8. Black and Decker Pivot MAX Power Switch Replacement, Power Switch: 步骤 8 中的图像 1,3 Black and Decker Pivot MAX Power Switch Replacement, Power Switch: 步骤 8 中的图像 2,3 Black and Decker Pivot MAX Power Switch Replacement, Power Switch: 步骤 8 中的图像 3,3
    • Lift the battery tray after removing the screws
    • Remove the handle parts from the handle area.
  9. Black and Decker Pivot MAX Power Switch Replacement: 步骤 9 中的图像 1,2 Black and Decker Pivot MAX Power Switch Replacement: 步骤 9 中的图像 2,2
    • Pull the power switch out softly.
    • Desolder the wires from the old power switch to the new one.
    • Check out our 如何焊接和拆焊 guide if you need any help!
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 12
总计 938
