跳转到主内容
Black and Decker LDX172C Trigger Switch Replacement
你所需要的
  1. Black and Decker LDX172C Trigger Switch Replacement, Trigger Switch: 步骤 1 中的图像 1,1
    • Before beginning, make sure the motor direction switch is in the neutral position.
    • Place the drill on the work surface with the chuck facing downward. Locate and remove the two #2 X 10mm Phillips screws located right of the motor.
  2. Black and Decker LDX172C Trigger Switch Replacement: 步骤 2 中的图像 1,1
    • Rotate the drill to it's left side - the chuck should be facing to the right. Locate and remove the eight #2 X 5mm Phillips fasteners from the body of the drill.
  3. Black and Decker LDX172C Trigger Switch Replacement: 步骤 3 中的图像 1,1
    • Carefully remove the right half of the body from the drill.
    • The trigger mechanism is spring loaded and may eject from the drill when the body is removed.
  4. Black and Decker LDX172C Trigger Switch Replacement: 步骤 4 中的图像 1,3 Black and Decker LDX172C Trigger Switch Replacement: 步骤 4 中的图像 2,3 Black and Decker LDX172C Trigger Switch Replacement: 步骤 4 中的图像 3,3
    • Remove trigger from drill by pulling the mechanism directly up off the holding pins.
    • The leads from the switch are removed by using a heating the solder until they come free.
    • Re-solder the leads to the new switch.
    • Repeat directions in reverse to reassemble.
结论
团队
IUPUI, Team 3-3, Wilson Spring 2016 IUPUI, Team 3-3, Wilson Spring 2016 的会员
IUPUI-WILSON-S16S3G3
4 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 22
总计 3,191
