简介
One of the reasons you would replace the safety switch is if it does not alternate between the on and off position. The switch could be stuck or jammed, If this is the case then we would need to replace it. Some of the tools needed to repair this will be a soldering iron and soldering flux. In order to complete this repair, some soldering skills will be required.
你所需要的
After following the prerequisite guide, the interior components of the drill can now be accessed.
To reassemble your device, follow these instructions in reverse order, re-soldering wires where necessary.
另外一个人完成了本指南。
