跳转到主内容
Bike Chain Installation
你所需要的
  1. Bike Chain Installation, Bike Chain Installation: 步骤 1 中的图像 1,2 Bike Chain Installation, Bike Chain Installation: 步骤 1 中的图像 2,2
    • Rout the chain around the front chain rings and rear derailleur.
    • Pull the ends of the chain together.
  2. Bike Chain Installation: 步骤 2 中的图像 1,2 Bike Chain Installation: 步骤 2 中的图像 2,2
    • Use the chain cutter tool to press the chain pin back through the chain link. If it is difficult to push it back in, the links are not aligned properly. Realign and try again if this is the case.
    • Caution: Reusing pins in chains can cause the chain to fail. This is because the pins are press fit into link. Using a new pin when assembling a chain is recommend for long term use.
终点
3等其他人完成本指南。
aaron thielk
于10/10/10注册
1,903 声望
创作了5篇指南
团队
Cal Poly, Team 5-13, Maness Fall 2010 Cal Poly, Team 5-13, Maness Fall 2010 的会员
CPSU-MANESS-F10S5G13
4 名成员
创作了17篇指南
2条评论
what do you do if the Chain keeps Falling off when your Riding the Bike an the Chain still rubs against the tire .
Anthony - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 11
过去 30 天: 47
总计 16,458
