跳转到主内容
Beiens Cartoon RC Race Car LED Light Replacement
你所需要的
  1. Beiens Cartoon RC Race Car LED Light Replacement, LED Light: 步骤 1 中的图像 1,1
    • Hold the remote control with the backside facing you and, using the Phillips #00 screwdriver, unscrew the six 6.5 mm screws on the back of the controller that hold it together.
  2. Beiens Cartoon RC Race Car LED Light Replacement: 步骤 2 中的图像 1,1
    • Open the remote control.
  3. Beiens Cartoon RC Race Car LED Light Replacement: 步骤 3 中的图像 1,1
    • Lift the motherboard to separate it from the remote control.
  4. Beiens Cartoon RC Race Car LED Light Replacement: 步骤 4 中的图像 1,1
    • To remove the light, use a soldering iron to heat the solder to a liquid and loosen the leads.
    • While the solder is liquid, lightly pull on the LED to remove it from the motherboard.
    • The soldering iron will get very hot while it's in use. Be sure to place it on top of a heat protected surface and be careful not to touch the operational end.
结论
Amber Ashley
于10/01/15注册
329 声望
创作了4篇指南
团队
USF Tampa, Team 1-6, Leahy Fall 2015 USF Tampa, Team 1-6, Leahy Fall 2015 的会员
USFT-LEAHY-F15S1G6
3 名成员
创作了8篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 7
总计 295
