跳转到主内容
Behringer BCD3000 Disassembly
你所需要的
  1. Behringer BCD3000 Disassembly, Behringer BCD3000 Disassembly: 步骤 1 中的图像 1,1
    • Unplug from all cables
  2. Behringer BCD3000 Disassembly, opening the sides: 步骤 2 中的图像 1,2 Behringer BCD3000 Disassembly, opening the sides: 步骤 2 中的图像 2,2
    • unscrew two Phillips screws on each side of the BCD3000
    • If the screws sit too tight, you can use the extension for better torque
  3. Behringer BCD3000 Disassembly, loosening the top part: 步骤 3 中的图像 1,2 Behringer BCD3000 Disassembly, loosening the top part: 步骤 3 中的图像 2,2
    • unscrew another two Phillips screws on each side
  4. Behringer BCD3000 Disassembly: 步骤 4 中的图像 1,3 Behringer BCD3000 Disassembly: 步骤 4 中的图像 2,3 Behringer BCD3000 Disassembly: 步骤 4 中的图像 3,3
    • Lift the upper control part.
    • Be careful, there are still some cables connected to the lower section.
    • Disconnect the cables by walking them out of their sockets.
  5. Behringer BCD3000 Disassembly: 步骤 5 中的图像 1,1
    • Remove the upper part completely.
  6. Behringer BCD3000 Disassembly: 步骤 6 中的图像 1,1
    • Disconnect the two cables from the lower section to the connector board.
  7. Behringer BCD3000 Disassembly: 步骤 7 中的图像 1,3 Behringer BCD3000 Disassembly: 步骤 7 中的图像 2,3 Behringer BCD3000 Disassembly: 步骤 7 中的图像 3,3
    • Slide the lower section to the front.
    • Now you can lift it and take it aside.
  8. Behringer BCD3000 Disassembly: 步骤 8 中的图像 1,3 Behringer BCD3000 Disassembly: 步骤 8 中的图像 2,3 Behringer BCD3000 Disassembly: 步骤 8 中的图像 3,3
    • Disconnect the separate boards.
    • Now you can take the modules out by unscrewing them from the case.
  9. Behringer BCD3000 Disassembly: 步骤 9 中的图像 1,2 Behringer BCD3000 Disassembly: 步骤 9 中的图像 2,2
    • The jog wheels on the front panel can be taken off by using a spudger and levering them out.
  10. Behringer BCD3000 Disassembly: 步骤 10 中的图像 1,2 Behringer BCD3000 Disassembly: 步骤 10 中的图像 2,2
    • The knobs can easy be removed just by pulling.
  11. Behringer BCD3000 Disassembly: 步骤 11 中的图像 1,3 Behringer BCD3000 Disassembly: 步骤 11 中的图像 2,3 Behringer BCD3000 Disassembly: 步骤 11 中的图像 3,3
    • Same goes for the knobs on the top section of the front panel.
结论
4等其他人完成本指南。
Tobias Isakeit
于03/31/14注册
114,491 声望
创作了188篇指南
团队
IMHO IMHO 的会员
Business
1 名成员
创作了1,072篇指南
2条评论
Pensaba que serviría para la BCD2000… pero es algo distinta.
Antonio - 回复
great stuff, with better quality pictures would be better
csipapicsa - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 24
总计 2,260
