跳转到主内容
Beboncool Gamepad for Nintendo Switch Battery Replacement
你所需要的
  1. Beboncool Gamepad for Nintendo Switch Battery Replacement, Beboncool Nintendo Switch Gamepad Disassembly: 步骤 1 中的图像 1,3 Beboncool Gamepad for Nintendo Switch Battery Replacement, Beboncool Nintendo Switch Gamepad Disassembly: 步骤 1 中的图像 2,3 Beboncool Gamepad for Nintendo Switch Battery Replacement, Beboncool Nintendo Switch Gamepad Disassembly: 步骤 1 中的图像 3,3
    • Use the plastic opening tool to remove the blue plastic grips from the sides of the controller.
  2. Beboncool Gamepad for Nintendo Switch Battery Replacement: 步骤 2 中的图像 1,2 Beboncool Gamepad for Nintendo Switch Battery Replacement: 步骤 2 中的图像 2,2
    • Use the Phillips #0 screwdriver to remove the seven 5mm screws from the back of the controller.
  3. Beboncool Gamepad for Nintendo Switch Battery Replacement: 步骤 3 中的图像 1,3 Beboncool Gamepad for Nintendo Switch Battery Replacement: 步骤 3 中的图像 2,3 Beboncool Gamepad for Nintendo Switch Battery Replacement: 步骤 3 中的图像 3,3
    • Gently separate the two halves of the controller.
    • As the two covers come apart the L1 and R1 button, will fall free from the controller. Be sure not to lose them if they should pop out and fall.
    • Be sure to slide the small circuit boards out of the covers to be able to separate the two halves
  4. Beboncool Gamepad for Nintendo Switch Battery Replacement: 步骤 4 中的图像 1,2 Beboncool Gamepad for Nintendo Switch Battery Replacement: 步骤 4 中的图像 2,2
    • Use the Phillips #0 screwdriver to remove the two 3.5mm screws holding the circuit board in place.
  5. Beboncool Gamepad for Nintendo Switch Battery Replacement: 步骤 5 中的图像 1,3 Beboncool Gamepad for Nintendo Switch Battery Replacement: 步骤 5 中的图像 2,3 Beboncool Gamepad for Nintendo Switch Battery Replacement: 步骤 5 中的图像 3,3
    • Lift the motherboard from the back case with the vibration motors and button boards attached.
  6. Beboncool Gamepad for Nintendo Switch Battery Replacement, Battery: 步骤 6 中的图像 1,3 Beboncool Gamepad for Nintendo Switch Battery Replacement, Battery: 步骤 6 中的图像 2,3 Beboncool Gamepad for Nintendo Switch Battery Replacement, Battery: 步骤 6 中的图像 3,3
    • Carefully separate the battery which is adhered to the circuit board.
  7. Beboncool Gamepad for Nintendo Switch Battery Replacement: 步骤 7 中的图像 1,3 Beboncool Gamepad for Nintendo Switch Battery Replacement: 步骤 7 中的图像 2,3 Beboncool Gamepad for Nintendo Switch Battery Replacement: 步骤 7 中的图像 3,3
结论
另外一个人完成了本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 21
总计 594
