跳转到主内容
Beats Studio3 Wireless Speaker Replacement
你所需要的
  1. Beats Studio3 Wireless Speaker Replacement, Ear Pad: 步骤 1 中的图像 1,2 Beats Studio3 Wireless Speaker Replacement, Ear Pad: 步骤 1 中的图像 2,2
    • Find the separation between the headset and ear cushion.
    • Use an opening tool to go underneath the separation site and split the pieces apart.
  2. Beats Studio3 Wireless Speaker Replacement: 步骤 2 中的图像 1,3 Beats Studio3 Wireless Speaker Replacement: 步骤 2 中的图像 2,3 Beats Studio3 Wireless Speaker Replacement: 步骤 2 中的图像 3,3
    • You can also use your hands to remove it completely.
    • Pulling it off can be challenging; make sure to apply enough pressure.
  3. Beats Studio3 Wireless Speaker Replacement, Speaker: 步骤 3 中的图像 1,2 Beats Studio3 Wireless Speaker Replacement, Speaker: 步骤 3 中的图像 2,2
    • Remove seven 3.6 mm screws holding the speaker assembly in place using a Phillips #0 screwdriver.
    • Make sure the screws aren't close to the speaker; due to it being a magnet, the screws could get stuck and damage the speaker.
    • Open the speaker by pulling the top layer of the speaker.
  4. Beats Studio3 Wireless Speaker Replacement: 步骤 4 中的图像 1,3 Beats Studio3 Wireless Speaker Replacement: 步骤 4 中的图像 2,3 Beats Studio3 Wireless Speaker Replacement: 步骤 4 中的图像 3,3
    • With a heat gun or hair dryer, heat the glue that is sticking the wires down until the glue softens.
    • Use a nylon spudger to remove the glue.
    • Pull on the wire to remove it while also removing the blue rubber band.
  5. Beats Studio3 Wireless Speaker Replacement: 步骤 5 中的图像 1,3 Beats Studio3 Wireless Speaker Replacement: 步骤 5 中的图像 2,3 Beats Studio3 Wireless Speaker Replacement: 步骤 5 中的图像 3,3
    • Using a soldering iron to remove the cables on the charger port.
    • For help with soldering, check out the How to Solder and Desolder Connections guide.
    • Remove the two wires connected in the middle of the speaker using a soldering iron.
    • Remove the speaker from the headset.
结论
Nayeli watts
于03/16/23注册
474 声望
创作了3篇指南
团队
UMass Dartmouth, Team 7-4, Ryckebusch Spring 2023 UMass Dartmouth, Team 7-4, Ryckebusch Spring 2023 的会员
UMASSD-RYCKEBUSCH-S23S7G4
3 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 12
过去 30 天: 68
总计 809
