跳转到主内容
Beats Studio 2 Wireless Battery Replacement
你所需要的
  1. Beats Studio 2 Wireless Battery Replacement, Battery: 步骤 1 中的图像 1,2 Beats Studio 2 Wireless Battery Replacement, Battery: 步骤 1 中的图像 2,2
    • Using a spudger, remove the panel circling the ‘b’ Beats logo on the right earphone by applying pressure upwards under the panel until it is removed.
  2. Beats Studio 2 Wireless Battery Replacement: 步骤 2 中的图像 1,2 Beats Studio 2 Wireless Battery Replacement: 步骤 2 中的图像 2,2
    • Remove the four screws securing the housing with a Phillips #00 screwdriver.
  3. Beats Studio 2 Wireless Battery Replacement: 步骤 3 中的图像 1,1
    • Use a spudger to release the clip in the seam under the silver “studio” label.
    • Remove the right side of the headband.
  4. Beats Studio 2 Wireless Battery Replacement: 步骤 4 中的图像 1,1
    • Gently remove the right earphone speaker from the headband by sliding the speaker downwards.
  5. Beats Studio 2 Wireless Battery Replacement: 步骤 5 中的图像 1,3 Beats Studio 2 Wireless Battery Replacement: 步骤 5 中的图像 2,3 Beats Studio 2 Wireless Battery Replacement: 步骤 5 中的图像 3,3
    • Use the pointed tip of a spudger to carefully push on each side of the connector to release it from the socket on the motherboard.
    • Be gentle with the connectors as they can break easily.
    • Don't use a metal spudger to remove a battery or any internal component. This is potentially dangerous as it could puncture the battery and cause a fire or worse.
    • Use a nylon spudger to remove the battery from the headphones.
结论
2等其他人完成本指南。
Jack Wilson
于03/20/23注册
485 声望
创作了2篇指南
团队
UMass Dartmouth, Team 5-3, Ramos Spring 2023 UMass Dartmouth, Team 5-3, Ramos Spring 2023 的会员
UMASSD-RAMOS-S23S5G3
3 名成员
创作了4篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 55
过去 30 天: 190
总计 1,070
