跳转到主内容
Beats Solo 3 Motherboard Replacement
你所需要的
  1. Beats Solo 3 Motherboard Replacement, Motherboard: 步骤 1 中的图像 1,1
    • Use an opening tool to open the headband at the color seam.
    • The audio board is located inside the "Left" ear cup.
  2. Beats Solo 3 Motherboard Replacement: 步骤 2 中的图像 1,2 Beats Solo 3 Motherboard Replacement: 步骤 2 中的图像 2,2
    在这个步骤中使用的工具:
    购买
    • Use a pair of tweezers to carefully remove the yellow polyimide tape that is attached to the morherboard.
  3. Beats Solo 3 Motherboard Replacement: 步骤 3 中的图像 1,1
    • There will be three bundled cables attached to the motherboard. Carefully pull them out of each prong.
    • Make sure to take note of which one belongs where for reassembly later.
  4. Beats Solo 3 Motherboard Replacement: 步骤 4 中的图像 1,1
    • Use a Phillips #00 screwdriver to remove the four screws that hold the motherboard in place.
    • The cap on the outside of the headphones will fall off once the final screw is removed. Do not fear that something broke. Simply reattach during reassembly phase
  5. Beats Solo 3 Motherboard Replacement: 步骤 5 中的图像 1,1
    • Finally, remove and replace the motherboard.
结论
另外一个人完成了本指南。
3条评论
no suena el altavoz izquierdo do los cascos en modo inalambrico
supongo que es placa base
?puede decirme donde puedo comprar placa base?
l1967e - 回复
hey, I'm working on my headphones rn because of a connectivity issue. I believe I found the problem: one of the bottom bundled cables is cracked on the plastic casing that connects the wires to the motherboard, and it's the bottom one (the one unplugged in your picture). Do you know that that wire/cord does? is it related to the Bluetooth or connectivity of the headphones?
Evil Lemons - 回复
I also just saw your profile picture and I'm from Alabama, roll tide
Evil Lemons -
添加评论
浏览统计数据:
过去 24 小时: 6
过去 7 天: 43
过去 30 天: 267
总计 7,435
