跳转到主内容
Zenbre SoundBank Z3 Battery Replacement
你所需要的
  1. Zenbre SoundBank Z3 Battery Replacement, Bottom Cover: 步骤 1 中的图像 1,2 Zenbre SoundBank Z3 Battery Replacement, Bottom Cover: 步骤 1 中的图像 2,2
    • Power off the SoundBank Z3.
    • Turn over the device.
    • Peel the silicone feet up to remove.
    • No extra adhesive is needed to reapply the feet as long as the sticky side is not touched.
  2. Zenbre SoundBank Z3 Battery Replacement: 步骤 2 中的图像 1,1
    • Remove all eight of the 11 mm Phillips screws from the bottom of the device.
  3. Zenbre SoundBank Z3 Battery Replacement: 步骤 3 中的图像 1,2 Zenbre SoundBank Z3 Battery Replacement: 步骤 3 中的图像 2,2
    • Remove the bottom panel speaker using an iFixit opening tool.
  4. Zenbre SoundBank Z3 Battery Replacement, Motherboard Cover: 步骤 4 中的图像 1,3 Zenbre SoundBank Z3 Battery Replacement, Motherboard Cover: 步骤 4 中的图像 2,3 Zenbre SoundBank Z3 Battery Replacement, Motherboard Cover: 步骤 4 中的图像 3,3
    • Remove the four 4.5 mm silver Phillips screws that secure the plastic panel covering the motherboard.
    • Remove the plastic panel.
  5. Zenbre SoundBank Z3 Battery Replacement, Battery: 步骤 5 中的图像 1,2 Zenbre SoundBank Z3 Battery Replacement, Battery: 步骤 5 中的图像 2,2
    • Remove the battery from the holder. It may be difficult the first time.
    • Use a spudger between the battery and speaker wall to loosen it from its surroundings.
    • If the battery is punctured, leaking, or bloated/puffy, it may be hazardous and should be properly disposed of.
  6. Zenbre SoundBank Z3 Battery Replacement: 步骤 6 中的图像 1,2 Zenbre SoundBank Z3 Battery Replacement: 步骤 6 中的图像 2,2
    • Remove the pressure-fitted foam from the slot by hand.
    • Unravel and remove foam from the wires.
    • When reassembling, the foam can be re-wrapped if care is taken when handling it.
  7. Zenbre SoundBank Z3 Battery Replacement: 步骤 7 中的图像 1,1
    • Using a soldering iron, remove the leads, separating the battery from motherboard.
    • Follow this guide to help you remove the wires from the motherboard if you are unfamiliar with soldering.
结论
3等其他人完成本指南。
Cherian Thomas
于03/25/16注册
334 声望
创作了5篇指南
团队
UMass Dartmouth, Team 3-2, Bhusal Spring 2016 UMass Dartmouth, Team 3-2, Bhusal Spring 2016 的会员
UMASSD-BHUSAL-S16S3G2
5 名成员
创作了8篇指南
3条评论
Thank you for providing battery replacement instructions for the ZENGRE BlueTooth speaker system. They are very helpful.
Michael Coleman - 回复
Bendiciones. con que batería la reemplazaste? podrías enviarme un link para comprarlo, desde ya muchas gracias
Alier Obed Jaenz Rivas -
MUCHAS GRACIAS!!!!
Sin embargo hubiese sido exelente pudiese mostrarse los tipos de batería con los cuales se puede reemplazar.
Alier Obed Jaenz Rivas - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 11
总计 4,575
