跳转到主内容
Battery Disconnection
仅作为前提条件
本指南仅提供前提条件!本指南是另一个程序的一部分,不能单独使用。
你所需要的
  1. Battery Disconnection, Prepare your laptop for disassembly: 步骤 1 中的图像 1,3 Battery Disconnection, Prepare your laptop for disassembly: 步骤 1 中的图像 2,3 Battery Disconnection, Prepare your laptop for disassembly: 步骤 1 中的图像 3,3
    • Before starting this repair, allow your laptop's battery to drain below 25%. A charged battery may catch fire if damaged.
    • Unplug all cables and fully shut down your laptop.
  2. Battery Disconnection, Flip your laptop over: 步骤 2 中的图像 1,3 Battery Disconnection, Flip your laptop over: 步骤 2 中的图像 2,3 Battery Disconnection, Flip your laptop over: 步骤 2 中的图像 3,3
    • Close your laptop and lay it down so the rubber feet are facing up.
  3. Battery Disconnection, Remove the feet: 步骤 3 中的图像 1,3 Battery Disconnection, Remove the feet: 步骤 3 中的图像 2,3 Battery Disconnection, Remove the feet: 步骤 3 中的图像 3,3
    • Gently slide one arm of your angled tweezers into the recess near the upper right edge of one of the feet.
    • You can also use the point of a spudger. However, you're more likely to damage the foot, if you're reusing it.
    • Use your tweezers to pry up and remove the foot.
    • The feet may eject very quickly—be careful not to lose them.
    • Repeat the process to remove the remaining feet.
    • To install a foot, align the pegs on the bottom with their cutouts in the frame and press the foot into place.
  4. Battery Disconnection, Remove the lower case screws: 步骤 4 中的图像 1,2 Battery Disconnection, Remove the lower case screws: 步骤 4 中的图像 2,2
    在这个步骤中使用的工具:
    FixMat
    $36.95
    • While the Surface Laptop 7 uses Torx Plus screws, standard Torx bits work. Make sure to apply constant, downward force to prevent stripping.
    • Use a Torx Plus 5IP screwdriver to remove the four 4.5 mm‑long screws (with washers) securing the lower case.
  5. Battery Disconnection, Detach the lower case: 步骤 5 中的图像 1,3 Battery Disconnection, Detach the lower case: 步骤 5 中的图像 2,3 Battery Disconnection, Detach the lower case: 步骤 5 中的图像 3,3
    • Insert the tip of an opening pick under the top edge of the lower case, about an inch (2.5 cm) to the left or right of the Microsoft logo.
    • Don't insert the pick near the outer edges or you'll damage the antenna bar.
  6. Battery Disconnection: 步骤 6 中的图像 1,3 Battery Disconnection: 步骤 6 中的图像 2,3 Battery Disconnection: 步骤 6 中的图像 3,3
    • Twist the pick to lift the lower case enough that you can grip it with your hand.
  7. Battery Disconnection, Remove the lower case: 步骤 7 中的图像 1,3 Battery Disconnection, Remove the lower case: 步骤 7 中的图像 2,3 Battery Disconnection, Remove the lower case: 步骤 7 中的图像 3,3
    • Lift the lower case and remove it.
  8. Battery Disconnection, Disconnect the battery: 步骤 8 中的图像 1,3 Battery Disconnection, Disconnect the battery: 步骤 8 中的图像 2,3 Battery Disconnection, Disconnect the battery: 步骤 8 中的图像 3,3
    • Use a Torx Plus 3IP screwdriver to remove the two 2.3 mm‑long screws securing the battery connector cover.
  9. Battery Disconnection: 步骤 9 中的图像 1,2 Battery Disconnection: 步骤 9 中的图像 2,2
    • Use tweezers or your fingers to remove the battery connector cover.
  10. Battery Disconnection: 步骤 10 中的图像 1,2 Battery Disconnection: 步骤 10 中的图像 2,2
    • Insert the flat end of a spudger under the top edge of the battery press connector and pry up to disconnect it.
    • To reconnect a press connector, align it over the socket and gently press down on one side until it clicks into place, then press down on the other side. It may take a few tries to align the connector—don't try to force it into place.
终点
Spencer Day
于09/14/22注册
155,533 声望
创作了1,033篇指南
团队
iFixit iFixit 的会员
Staff
123 名成员
创作了23,791篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 41
