跳转到主内容
加入维修社区 - 创建账户
Base Removal
仅作为前提条件
本指南仅提供前提条件!本指南是另一个程序的一部分,不能单独使用。
你所需要的
  1. Base Removal, Uncover the back panel screws: 步骤 1 中的图像 1,2 Base Removal, Uncover the back panel screws: 步骤 1 中的图像 2,2
    • Before you begin, completely power down and unplug all cables from your console.
    • Two stickers cover the back panel screws. You can remove the stickers without heating them, though it makes them much easier to remove cleanly.
    • Heat an iOpener and lay it on the smaller sticker near the bottom of the back panel for two minutes.
    • Alternatively, you can use a hair dryer to heat the sticker.
  2. Base Removal: 步骤 2 中的图像 1,3 Base Removal: 步骤 2 中的图像 2,3 Base Removal: 步骤 2 中的图像 3,3
    • Use a pair of angled tweezers to remove the sticker hiding the first screw on the back panel, near the base.
  3. Base Removal: 步骤 3 中的图像 1,3 Base Removal: 步骤 3 中的图像 2,3 Base Removal: 步骤 3 中的图像 3,3
    • Use an iOpener or hair dryer to heat the larger sticker near the center of the back panel.
  4. Base Removal: 步骤 4 中的图像 1,3 Base Removal: 步骤 4 中的图像 2,3 Base Removal: 步骤 4 中的图像 3,3
    • Use the flat end of a spudger to scrape up a corner of the larger sticker until you can grip it with a pair of blunt tweezers.
    • Use blunt tweezers to peel back the sticker to reveal the second screw.
    • You only need to peel this sticker to where you can access the hidden screw. You don't need to pull it completely off.
    • Technically, these are tamper-evident stickers, but don't worry—Microsoft can't legally void your warranty, as long as you don't damage anything. Have fun!
  5. Base Removal, Remove the back panel screws: 步骤 5 中的图像 1,2 Base Removal, Remove the back panel screws: 步骤 5 中的图像 2,2
    在这个步骤中使用的工具:
    Magnetic Project Mat
    $19.95
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your console.
    • Use a T8 Torx driver to remove the two 7.4 mm‑long screws securing the back panel.
  6. Base Removal, Unclip the back panel: 步骤 6 中的图像 1,3 Base Removal, Unclip the back panel: 步骤 6 中的图像 2,3 Base Removal, Unclip the back panel: 步骤 6 中的图像 3,3
    • Insert the flat end of a spudger into the gap between the back panel and the shell, near the left side of the base.
    • Pry up the back panel to release it from the locking clips.
  7. Base Removal: 步骤 7 中的图像 1,3 Base Removal: 步骤 7 中的图像 2,3 Base Removal: 步骤 7 中的图像 3,3
    • Insert the flat end of a spudger into the gap between the back panel and the shell, near the right side of the base.
  8. Base Removal, Remove the back panel: 步骤 8 中的图像 1,3 Base Removal, Remove the back panel: 步骤 8 中的图像 2,3 Base Removal, Remove the back panel: 步骤 8 中的图像 3,3
    • Grip the back panel at the opening you just created and pull it up and away from the shell to unclip the long edges.
    • During reassembly, press along the edges of the back panel to snap it into place.
  9. Base Removal: 步骤 9 中的图像 1,3 Base Removal: 步骤 9 中的图像 2,3 Base Removal: 步骤 9 中的图像 3,3
    • The back panel slots into a gap at the top of the shell.
    • Tilt the back panel up and pull it away from the top edge of the shell to release it from the gap.
    • Remove the back panel.
  10. Base Removal, Unlatch the base: 步骤 10 中的图像 1,3 Base Removal, Unlatch the base: 步骤 10 中的图像 2,3 Base Removal, Unlatch the base: 步骤 10 中的图像 3,3
    • Use the flat end of a spudger to pry up the locking tab holding the base to the shell.
    • Keep the locking tab held open for the next step.
  11. Base Removal, Twist and remove the base: 步骤 11 中的图像 1,3 Base Removal, Twist and remove the base: 步骤 11 中的图像 2,3 Base Removal, Twist and remove the base: 步骤 11 中的图像 3,3
    • With the locking tab held open, grip the base and rotate it counterclockwise to unlock it from the shell.
    • Remove the base.
    • During reassembly, put the base tabs into their holes on the shell and twist clockwise until the base snaps into the interior locking tab.
    • When locked in place, the Hello from Seattle line will be parallel with the device's sides.
结论
Spencer Day
于09/14/22注册
158,429 声望
创作了1,043篇指南
团队
iFixit iFixit 的会员
Staff
123 名成员
创作了23,895篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 11
总计 71
