简介
Use this guide to replace the left bumper in your Backbone One.
你所需要的
Lift up the upper part of the controller.
Swing over the upper cover and place it on the controller case.
在这个步骤中使用的工具:Tweezers$4.99
Use a pair of tweezers to remove the yellow protective tape which is placed over the interconnect cable connector.
Use the tip of an opening pick to open the gray flap of the ZIF connector by pushing it upwards.
Use your fingers to disconnect the interconnect cable from its connector.
Use a Phillips screwdriver to remove the 5.9 mm-long screw which is securing the trigger.
