跳转到主内容
加入维修社区 - 创建账户
Backbone One Left Bumper Replacement
你所需要的
  1. Backbone One Left Bumper Replacement, Unfasten the screws: 步骤 1 中的图像 1,1
    • Use a Phillips screwdriver to remove the four 5.9 mm-long screws.
  2. Backbone One Left Bumper Replacement, Rotate the upper cover: 步骤 2 中的图像 1,3 Backbone One Left Bumper Replacement, Rotate the upper cover: 步骤 2 中的图像 2,3 Backbone One Left Bumper Replacement, Rotate the upper cover: 步骤 2 中的图像 3,3
    • Lift up the upper part of the controller.
    • Swing over the upper cover and place it on the controller case.
    • Take care that the interconnecting cable has no tension.
  3. Backbone One Left Bumper Replacement, Remove the protective tape: 步骤 3 中的图像 1,3 Backbone One Left Bumper Replacement, Remove the protective tape: 步骤 3 中的图像 2,3 Backbone One Left Bumper Replacement, Remove the protective tape: 步骤 3 中的图像 3,3
    在这个步骤中使用的工具:
    • Use a pair of tweezers to remove the yellow protective tape which is placed over the interconnect cable connector.
  4. Backbone One Left Bumper Replacement, Open the ZIF connector: 步骤 4 中的图像 1,2 Backbone One Left Bumper Replacement, Open the ZIF connector: 步骤 4 中的图像 2,2
    • Use the tip of an opening pick to open the gray flap of the ZIF connector by pushing it upwards.
  5. Backbone One Left Bumper Replacement, Disconnect the interconnect cable: 步骤 5 中的图像 1,2 Backbone One Left Bumper Replacement, Disconnect the interconnect cable: 步骤 5 中的图像 2,2
    • Use your fingers to disconnect the interconnect cable from its connector.
  6. Backbone One Left Bumper Replacement: 步骤 6 中的图像 1,2 Backbone One Left Bumper Replacement: 步骤 6 中的图像 2,2
    • Remove the upper half of the left controller assembly.
  7. Backbone One Left Bumper Replacement, Remove the screw: 步骤 7 中的图像 1,2 Backbone One Left Bumper Replacement, Remove the screw: 步骤 7 中的图像 2,2
    • Use a Phillips screwdriver to remove the 5.9 mm-long screw which is securing the trigger.
    • The screw is difficult to reach. Insert the screwdriver at an angle of 45 degrees.
  8. Backbone One Left Bumper Replacement, Remove the trigger: 步骤 8 中的图像 1,2 Backbone One Left Bumper Replacement, Remove the trigger: 步骤 8 中的图像 2,2
    • Remove the left trigger.
  9. Backbone One Left Bumper Replacement, Remove the bumper: 步骤 9 中的图像 1,2 Backbone One Left Bumper Replacement, Remove the bumper: 步骤 9 中的图像 2,2
    • Use your fingers to remove the left bumper.
结论
Adriana Zwink
于12/18/19注册
63,090 声望
创作了167篇指南
团队
iFixit iFixit 的会员
Staff
123 名成员
创作了23,891篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 15
总计 1,132
