跳转到主内容
Back Cover Removal
仅作为前提条件
本指南仅提供前提条件!本指南是另一个程序的一部分,不能单独使用。
你所需要的
  1. Back Cover Removal, Prepare your device for disassembly: 步骤 1 中的图像 1,3 Back Cover Removal, Prepare your device for disassembly: 步骤 1 中的图像 2,3 Back Cover Removal, Prepare your device for disassembly: 步骤 1 中的图像 3,3
    • Let your device's battery drain below 25% before starting this repair—a charged lithium‑ion battery may catch fire if damaged.
    • Completely power off your device and unplug all cables.
    • Consider laying your device on a soft cloth to prevent scratching or damaging the screen during your repair.
  2. Back Cover Removal, Unfasten the back cover: 步骤 2 中的图像 1,2 Back Cover Removal, Unfasten the back cover: 步骤 2 中的图像 2,2
    在这个步骤中使用的工具:
    FixMat
    $36.95
    • Use a Phillips #0 screwdriver to remove the five 17.2 mm‑long screws securing the top edge and bottom corners of the back cover.
    • Use a Phillips #0 screwdriver to fully loosen the remaining captive screw at the center of the bottom edge. This should create a small gap between the back cover and chassis.
    • Don't try to remove this screw.
  3. Back Cover Removal, Insert an opening pick: 步骤 3 中的图像 1,3 Back Cover Removal, Insert an opening pick: 步骤 3 中的图像 2,3 Back Cover Removal, Insert an opening pick: 步骤 3 中的图像 3,3
    • Insert the flat edge of an opening pick between the bottom edge of the back cover and chassis, near the captive screw.
    • Angle the pick upward and push it under the back cover.
  4. Back Cover Removal, Release the back cover's clips: 步骤 4 中的图像 1,3 Back Cover Removal, Release the back cover's clips: 步骤 4 中的图像 2,3 Back Cover Removal, Release the back cover's clips: 步骤 4 中的图像 3,3
    • Plastic clips secure the perimeter of the back cover. You should feel and hear them release during this step.
    • Slide the opening pick along the bottom edge and around the corners of the back cover to release the clips securing it.
    • Keep the pick at an upward angle under the back cover to help release the clips.
  5. Back Cover Removal, Remove the back cover: 步骤 5 中的图像 1,3 Back Cover Removal, Remove the back cover: 步骤 5 中的图像 2,3 Back Cover Removal, Remove the back cover: 步骤 5 中的图像 3,3
    • Lift the bottom edge of the back cover off the chassis to release the remaining clips.
    • Remove the back cover.
    • During reassembly, lay the back cover onto your device and firmly push down around the perimeter to engage the clips.
结论
Spencer Day
于09/14/22注册
156,218 声望
创作了1,033篇指南
团队
iFixit iFixit 的会员
Staff
123 名成员
创作了23,829篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 96
