简介
The motor in the machine starts, but nothing moves? The belt is probably torn, which you can get for a lot of money from BOSCH or, if you know what to look for, from other dealers directly.
Here are the instructions for replacing the belts.
你所需要的
Open 4 cross screws
Loosen some plastic latches
Simply "pull off" the knob while or before opening the housing
Loosen screw
Turn back the plastic-tensioner so that the gear seperates from the rest
Pull the black cap off the axle
Flip the longer belt over the pulley
Unscrew 3 screws to remove the plastic cover
Lever out the clamps to remove the axle and take out the belts
Remove the clutch / gearbox
Insert new belts with the axle
Tension the 3M belts and reassemble everything
Work through the steps in reverse order to reassemble your unit.
另外一个人完成了本指南。
由衷感谢以下译者:
100%
Moritz Graf正在帮助我们修复这个世界! 您也想加入吗?
开始翻译 ›
