跳转到主内容
BLU Vivo One Plus Camera Replacement
你所需要的
  1. BLU Vivo One Plus Camera Replacement, Battery: 步骤 1 中的图像 1,3 BLU Vivo One Plus Camera Replacement, Battery: 步骤 1 中的图像 2,3 BLU Vivo One Plus Camera Replacement, Battery: 步骤 1 中的图像 3,3
    在这个步骤中使用的工具:
    SIM Card Eject Tool
    $2.99
    购买
  2. BLU Vivo One Plus Camera Replacement: 步骤 2 中的图像 1,3 BLU Vivo One Plus Camera Replacement: 步骤 2 中的图像 2,3 BLU Vivo One Plus Camera Replacement: 步骤 2 中的图像 3,3
    在这个步骤中使用的工具:
    iFixit Opening Tool
    $1.99
    购买
    • Use the plastic opening tool and run it under the entire seam that separates the screen and the plastic back of the phone.
    • Lodge the plastic opening tool under the back cover and use it to pry the two parts apart slowly.
    • This step will take a decent amount of force and it may seem as though the device will fracture, but you must keep pulling until the back releases.
  3. BLU Vivo One Plus Camera Replacement: 步骤 3 中的图像 1,2 BLU Vivo One Plus Camera Replacement: 步骤 3 中的图像 2,2
    在这个步骤中使用的工具:
    Phillips #000 Screwdriver
    $5.49
    购买
    • Using a Phillips 000 screwdriver, remove the 14 1.5 mm screws that attach the plastic protection cover to the phone.
    • Removing the screws will cause a silver metal bracket by the top left corner of the battery to fall off. Keep track of it for later.
  4. BLU Vivo One Plus Camera Replacement: 步骤 4 中的图像 1,2 BLU Vivo One Plus Camera Replacement: 步骤 4 中的图像 2,2
    在这个步骤中使用的工具:
    Spudger
    $3.99
    购买
    • After removing the screws, the bottom plastic cover will need to be removed to expose the rest of the phone’s interior.
    • The plastic cover should come off easily using your fingers, but you may need the spudger or an opening pick to remove it.
    • Remove the cover by its sides to ensure the removal is as easy as possible.
  5. BLU Vivo One Plus Camera Replacement: 步骤 5 中的图像 1,2 BLU Vivo One Plus Camera Replacement: 步骤 5 中的图像 2,2
    在这个步骤中使用的工具:
    iFixit Opening Picks (Set of 6)
    购买
    • Remove the two blue strips of tape on the lower portion of the battery.
    • After removing the blue strips of tape gently begin wedging the plastic picks underneath the battery and locating the adhesive tape strips.
    • Utilize the picks in a fashion that both pries the battery upward and scrapes the adhesive either loose from the battery or phone body. Be careful not to bend or damage the battery and it should eventually come free from the housing.
  6. BLU Vivo One Plus Camera Replacement: 步骤 6 中的图像 1,2 BLU Vivo One Plus Camera Replacement: 步骤 6 中的图像 2,2
  7. BLU Vivo One Plus Camera Replacement, Camera: 步骤 7 中的图像 1,3 BLU Vivo One Plus Camera Replacement, Camera: 步骤 7 中的图像 2,3 BLU Vivo One Plus Camera Replacement, Camera: 步骤 7 中的图像 3,3
    在这个步骤中使用的工具:
    购买
    • Using the flat blunt tweezers, grip the black and brown colored film that is lodged into a slot underneath a black holding ridge that connects the camera to the body of the phone.
    • Gently pull with the blunt tweezers on each side of the black and brown film until it slides out from beneath the ridge. Do this slowly to prevent ripping the film.
    • Keep hold of the film and pull away from the phone to dislodge the camera from its housing unit.
  8. BLU Vivo One Plus Camera Replacement: 步骤 8 中的图像 1,1
    在这个步骤中使用的工具:
    购买
    • Hold the new camera by its brown film piece using the blunt tweezers.
    • Using the blunt tweezers, place the top of the film under the holding ridge and gently push it into the slot.
    • Keep pushing the film into the slot until you can no longer see the white line on the film.
    • Use your fingers to lodge the body of the camera into its housing unit.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 235
