跳转到主内容
加入维修社区 - 创建账户
本篇指南是分解流程而非维修指南。 如果您要维修您的BLU Studio Mini 2023,应参考我们的维修指南
    1. BLU Studio Mini 2023 - Full Disassembly, Physical Overview: 步骤 1 中的图像 1,3 BLU Studio Mini 2023 - Full Disassembly, Physical Overview: 步骤 1 中的图像 2,3 BLU Studio Mini 2023 - Full Disassembly, Physical Overview: 步骤 1 中的图像 3,3
      • External ports
      • Micro USB 2.0
      • 3.5mm Headphone Combo Jack
      询问修复机器人
      添加评论
    2. BLU Studio Mini 2023 - Full Disassembly, Getting inside: 步骤 2 中的图像 1,3 BLU Studio Mini 2023 - Full Disassembly, Getting inside: 步骤 2 中的图像 2,3 BLU Studio Mini 2023 - Full Disassembly, Getting inside: 步骤 2 中的图像 3,3
      • Flip the device over and carefully unclip the back cover
      • Remove the battery
      询问修复机器人
      添加评论
    3. BLU Studio Mini 2023 - Full Disassembly, Screw types: 步骤 3 中的图像 1,2 BLU Studio Mini 2023 - Full Disassembly, Screw types: 步骤 3 中的图像 2,2
      • All screws used in the BLU Studio Mini 2023 have a PH0 head
      • Screw length and thread seems to be the same for all exterior screws (Black color)
      • Screw length and thread is different for the screw holding in the motherboard (Silver color). It will be distinguished later in the guide and is not pictured here
      询问修复机器人
      添加评论
    4. BLU Studio Mini 2023 - Full Disassembly, Top plastics: 步骤 4 中的图像 1,2 BLU Studio Mini 2023 - Full Disassembly, Top plastics: 步骤 4 中的图像 2,2
      • Remove the 8 total screws securing the top plastics
      • There are 7 screws, marked in pink
      • A single screw is hidden by a blue sticker, marked in yellow. It's the same type as the ones that were marked in pink
      • Gently pry off the top plastic, it has no adhesive and should pop off with minimal force
      询问修复机器人
      添加评论
    5. BLU Studio Mini 2023 - Full Disassembly, Bottom plastics: 步骤 5 中的图像 1,2 BLU Studio Mini 2023 - Full Disassembly, Bottom plastics: 步骤 5 中的图像 2,2
      • Remove the screws securing the bottom plastics
      • There are 7 screws total, marked in pink
      • Gently pry off the bottom plastic, it has no adhesive and should pop off with minimal force
      询问修复机器人
      添加评论
    6. BLU Studio Mini 2023 - Full Disassembly, Internal boards: 步骤 6 中的图像 1,1
      • The phone has two boards inside
      • The top board contains the phone's components, cameras, 3.5mm headphone combo jack, SIM card slot, MicroSD card slot and battery connector. It also connects to the button flex cable, display flex cable and board interconnect flex cable.
      • The bottom board contains the phone's MicroUSB 2.0 port and vibrator. It also connects to the board interconnect flex cable, the display digitizer flex cable and the internal speaker.
      询问修复机器人
      添加评论
    7. BLU Studio Mini 2023 - Full Disassembly, Removing the top board: 步骤 7 中的图像 1,3 BLU Studio Mini 2023 - Full Disassembly, Removing the top board: 步骤 7 中的图像 2,3 BLU Studio Mini 2023 - Full Disassembly, Removing the top board: 步骤 7 中的图像 3,3
      • Disconnect the flex cables on the board
      • Disconnect the button flex cable, it's a ZIF connector
      • Disconnect the display flex cable, it's a ZIF connector
      • Disconnect the board interconnect flex cable, it's a press connector
      • Unscrew the single silver screw holding in the motherboard and store it separately from the black exterior screws
      • Gently pry at the motherboard while minding the clip at the top of the board
      • Be mindful of the antenna wire on the back side of the board (circled in pink) when you remove the board
      询问修复机器人
      添加评论
    8. BLU Studio Mini 2023 - Full Disassembly, Removing the bottom board: 步骤 8 中的图像 1,3 BLU Studio Mini 2023 - Full Disassembly, Removing the bottom board: 步骤 8 中的图像 2,3 BLU Studio Mini 2023 - Full Disassembly, Removing the bottom board: 步骤 8 中的图像 3,3
      • Disconnect the digitizer flex cable, it's a ZIF connector
      • Make sure that you don't rip the digitizer flex cable while disconnecting it as it's partially adhered to the board (you can see it in image 2)
      • Be mindful of the antenna wire on the board (circled in pink) when removing the board
      添加评论
    9. BLU Studio Mini 2023 - Full Disassembly, End: 步骤 9 中的图像 1,2 BLU Studio Mini 2023 - Full Disassembly, End: 步骤 9 中的图像 2,2
      • That covers the scope of this teardown
      • From this point, the phone can actually be reassembled by following the instructions in reverse order and it should be fully functional as well
      询问修复机器人
      添加评论
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 26
过去 30 天: 113
总计 7,348
