跳转到主内容
BLU Life XL Headphone Port Replacement
你所需要的
  1. BLU Life XL Headphone Port Replacement, Volume Control Buttons: 步骤 1 中的图像 1,3 BLU Life XL Headphone Port Replacement, Volume Control Buttons: 步骤 1 中的图像 2,3 BLU Life XL Headphone Port Replacement, Volume Control Buttons: 步骤 1 中的图像 3,3
    • Turn the device off by holding down the power button for up to 5 seconds and then tapping the "Power off" button on the screen.
    • Remove the rear cover using your hands at the lip on the device back cover. No tools required.
    • Remove the battery by lifting the lower edge of the battery up first.
  2. BLU Life XL Headphone Port Replacement: 步骤 2 中的图像 1,2 BLU Life XL Headphone Port Replacement: 步骤 2 中的图像 2,2
    • Remove the 12x3mm screws from the rear plate using the Phillips#000 screwdriver.
  3. BLU Life XL Headphone Port Replacement: 步骤 3 中的图像 1,2 BLU Life XL Headphone Port Replacement: 步骤 3 中的图像 2,2
    • Firmly press the prying tool into the gap between the front glass and rear plate. This gap is located on all sides of the phone.
    • Run the prying tool around the entire phone separating the rear plate from the frame.
  4. BLU Life XL Headphone Port Replacement: 步骤 4 中的图像 1,3 BLU Life XL Headphone Port Replacement: 步骤 4 中的图像 2,3 BLU Life XL Headphone Port Replacement: 步骤 4 中的图像 3,3
    • Gently remove the tape covering the volume control buttons. The tape is located near the top left of the cavity for the battery.
    • Replace the component and reapply the tape over the buttons.
  5. BLU Life XL Headphone Port Replacement, Motherboard: 步骤 5 中的图像 1,2 BLU Life XL Headphone Port Replacement, Motherboard: 步骤 5 中的图像 2,2
    • Remove the two 12x3mm screws using the Phillips #000 screwdriver.
    • Remove the ribbon cables.
  6. BLU Life XL Headphone Port Replacement: 步骤 6 中的图像 1,3 BLU Life XL Headphone Port Replacement: 步骤 6 中的图像 2,3 BLU Life XL Headphone Port Replacement: 步骤 6 中的图像 3,3
    • The ribbon cables are attached by zero insertion force (ZIF) connectors. To disconnect the cable, flip up the small locking flap and pull the cable out.
  7. BLU Life XL Headphone Port Replacement: 步骤 7 中的图像 1,3 BLU Life XL Headphone Port Replacement: 步骤 7 中的图像 2,3 BLU Life XL Headphone Port Replacement: 步骤 7 中的图像 3,3
    在这个步骤中使用的工具:
    购买
    • Remove the white ZIF connector then remove the cable connecting the digitizer to the motherboard by gently pulling.
    • An adhesive pad attaches this component to the motherboard. To remove it, use a pair of tweezers to gently pry it upwards.
  8. BLU Life XL Headphone Port Replacement: 步骤 8 中的图像 1,3 BLU Life XL Headphone Port Replacement: 步骤 8 中的图像 2,3 BLU Life XL Headphone Port Replacement: 步骤 8 中的图像 3,3
    • The motherboard should now be free from its mount in the phone, but it is still connected to the PBC data cable. To remove the cable from the motherboard, gently pry upward.
    • The motherboard is now free and can be replaced.
  9. BLU Life XL Headphone Port Replacement, Headphone Port: 步骤 9 中的图像 1,2 BLU Life XL Headphone Port Replacement, Headphone Port: 步骤 9 中的图像 2,2
    • There are 5 soldering points holding the headphone jack to the motherboard. Desolder the 5 solder points and remove the jack.
    • For help with soldering and desoldering, check out this guide.
结论
Matthew Hook
于03/25/19注册
439 声望
创作了4篇指南
团队
IUPUI, Team S1-G6, Hovde Fall 2019 IUPUI, Team S1-G6, Hovde Fall 2019 的会员
IUPUI-HOVDE-F19S1G6
4 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 11
总计 147
