跳转到主内容
Azpen A740 Speaker Replacement
你所需要的
  1. Azpen A740 Speaker Replacement, Back Panel: 步骤 1 中的图像 1,1
    • Use the plastic opening tool or black spudger tool to lift the back panel off the tablet.
  2. Azpen A740 Speaker Replacement, Speaker: 步骤 2 中的图像 1,2 Azpen A740 Speaker Replacement, Speaker: 步骤 2 中的图像 2,2
    • The speaker will be attached by 2 screws with 3.75mm and 3.81mm at the bottom of the plastic holding the speaker in. These 2 screws will need to be removed in order to replace the speaker with a pentalobe screwdriver.
  3. Azpen A740 Speaker Replacement: 步骤 3 中的图像 1,2 Azpen A740 Speaker Replacement: 步骤 3 中的图像 2,2
    • Once the screws are removed, you should fully desolder the speaker wires that are attached to the motherboard. Instructions on how to desolder these wires are here on ifixit: 如何焊接和拆焊
    • After switching out the old speaker, just follow the directions in reverse to finish.
结论
Mallory
于01/21/15注册
346 声望
创作了3篇指南
团队
USF Tampa, Team 4-5, Brown Winter 2015 USF Tampa, Team 4-5, Brown Winter 2015 的会员
USFT-BROWN-W15S4G5
3 名成员
创作了12篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 6
总计 115
