跳转到主内容
Azpen A740 Battery Replacement
你所需要的
  1. Azpen A740 Battery Replacement, Back Panel: 步骤 1 中的图像 1,1
    • Use the plastic opening tool or black spudger tool to lift the back panel off the tablet.
  2. Azpen A740 Battery Replacement, Battery: 步骤 2 中的图像 1,2 Azpen A740 Battery Replacement, Battery: 步骤 2 中的图像 2,2
    • Use the set of plastic opening tools to separate the inner backing from the electronics.
    • Use the Phillips screwdriver to remove the 3.8 mm screws, holding the inner backing of Azpen A740 Tablet.
  3. Azpen A740 Battery Replacement: 步骤 3 中的图像 1,1
    • Disconnect the black, red, and grey wires leading to the battery from the motherboard using a soldering iron.
    • In order to desolder these connections follow the instructions on IFixit's How to Solder and Desolder Connections
  4. Azpen A740 Battery Replacement: 步骤 4 中的图像 1,2 Azpen A740 Battery Replacement: 步骤 4 中的图像 2,2
    • Remove the black tape that is holding the battery in place.
  5. Azpen A740 Battery Replacement: 步骤 5 中的图像 1,1
    • Remove the battery from the case using the blue prying or black spudger.
    • As you remove the battery it may be difficult to remove. Take your time to remove it carefully and try to avoid bending it.
结论
Maile Sinclair
于01/21/15注册
228 声望
创作了2篇指南
团队
USF Tampa, Team 4-5, Brown Winter 2015 USF Tampa, Team 4-5, Brown Winter 2015 的会员
USFT-BROWN-W15S4G5
3 名成员
创作了12篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 5
总计 1,621
