跳转到主内容
Azpen A720 Speaker Replacement
你所需要的
  1. Azpen A720 Speaker Replacement, Back Cover: 步骤 1 中的图像 1,2 Azpen A720 Speaker Replacement, Back Cover: 步骤 1 中的图像 2,2
    • Use a Phillips #00 screwdriver to remove the two 4mm screws found on the top edge of the tablet near the power button.
  2. Azpen A720 Speaker Replacement: 步骤 2 中的图像 1,3 Azpen A720 Speaker Replacement: 步骤 2 中的图像 2,3 Azpen A720 Speaker Replacement: 步骤 2 中的图像 3,3
    • Use the plastic opening tool to pry the white back from the silver frame. Start near the micro SD slot.
    • Slide the plastic opening tool around the perimeter of the casing until the back is disconnected.
  3. Azpen A720 Speaker Replacement: 步骤 3 中的图像 1,1
    • Remove the rear casing.
  4. Azpen A720 Speaker Replacement, Speaker: 步骤 4 中的图像 1,1
    • The speaker is a black oval located in the corner next to the battery.
  5. Azpen A720 Speaker Replacement: 步骤 5 中的图像 1,1
    • Use a soldering iron to desolder the connections between the black and red speaker wires and the motherboard.
    • Remember which lead the black and red wires connect to on the motherboard.
    • Caution: The soldering iron gets very hot; be careful not to touch the tip and burn yourself. To learn to solder, click here.
  6. Azpen A720 Speaker Replacement: 步骤 6 中的图像 1,1
    • Remove the speaker from the tablet.
结论
Anna
于03/17/15注册
353 声望
创作了3篇指南
团队
Michigan Tech, Team 1-3, Lauer Spring 2015 Michigan Tech, Team 1-3, Lauer Spring 2015 的会员
MTU-LAUER-S15S1G3
2 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 9
总计 246
