跳转到主内容
Azpen A701 Speaker Replacement
你所需要的
  1. Azpen A701 Speaker Replacement, Speaker: 步骤 1 中的图像 1,1
    • Wedge plastic spudger in between the back panel and the speaker of the device.
  2. Azpen A701 Speaker Replacement: 步骤 2 中的图像 1,2 Azpen A701 Speaker Replacement: 步骤 2 中的图像 2,2
    • Gently pry out the speaker from the back panel using the plastic spudger.
  3. Azpen A701 Speaker Replacement: 步骤 3 中的图像 1,1
    • Heat solder and apply to the wires where they attach to the motherboard. This will disconnect the wires from the motherboard.
    • The wires should still be attached to the speaker.
  4. Azpen A701 Speaker Replacement: 步骤 4 中的图像 1,1
    • Take the speaker and wires that are attached out of the device and insert a new speaker by soldering the wires to the motherboard.
结论
To reassemble your device, snap back piece back on to device and secure both 2cm screws at the bottom.
Grant Harding
于03/11/15注册
249 声望
创作了2篇指南
团队
Colorado Springs, Team 2-1, Panko Spring 2015 Colorado Springs, Team 2-1, Panko Spring 2015 的会员
UCCS-PANKO-S15S2G1
3 名成员
创作了12篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 8
总计 130
