跳转到主内容
Azpen A701 Motherboard Replacement
你所需要的
  1. Azpen A701 Motherboard Replacement, General Disassembly Prerequisite Guide: 步骤 1 中的图像 1,1
    • Remove the two 2cm screws on the bottom using the PH0 Phillips head screw driver.
  2. Azpen A701 Motherboard Replacement: 步骤 2 中的图像 1,2 Azpen A701 Motherboard Replacement: 步骤 2 中的图像 2,2
    • Pry open back piece with plastic spudger.
    • Remove the back piece of the device.
    • The back panel may be difficult to pry off, use gentle force.
  3. Azpen A701 Motherboard Replacement: 步骤 3 中的图像 1,1
    • Disconnect speaker (which is attached by black and red wires) from back piece using plastic spudger.
  4. Azpen A701 Motherboard Replacement: 步骤 4 中的图像 1,1
    • Gently pry the battery off of the device with the plastic spudger.
    • There is a large amount of glue holding the battery to the device.
    • Do not puncture the battery with the plastic spudger.
  5. Azpen A701 Motherboard Replacement, Motherboard: 步骤 5 中的图像 1,3 Azpen A701 Motherboard Replacement, Motherboard: 步骤 5 中的图像 2,3 Azpen A701 Motherboard Replacement, Motherboard: 步骤 5 中的图像 3,3
    • Remove all three ZIF cables connected to the motherboard (the blue, angled piece) by lifting the gray flap with your finger or a plastic spudger and gently removing the cable.
  6. Azpen A701 Motherboard Replacement: 步骤 6 中的图像 1,3 Azpen A701 Motherboard Replacement: 步骤 6 中的图像 2,3 Azpen A701 Motherboard Replacement: 步骤 6 中的图像 3,3
    • Remove the three 2cm screws at the bottom using the Phillips PH00 screwdriver head.
  7. Azpen A701 Motherboard Replacement: 步骤 7 中的图像 1,1
    • Gently peel off the orange sticker with the gray wire connected to the upper corner of the device. This is the antenna.
  8. Azpen A701 Motherboard Replacement: 步骤 8 中的图像 1,1
    • Remove solder connecting the battery to the motherboard using the soldering kit.
    • Place battery aside.
    • For more information on soldering, refer to iFixit's Soldering Guide.
  9. Azpen A701 Motherboard Replacement: 步骤 9 中的图像 1,1
    • Remove solder connecting the speaker wires to the motherboard.
    • Set speaker aside.
  10. Azpen A701 Motherboard Replacement: 步骤 10 中的图像 1,1
    • Remove solder connection the gray antenna wire to the motherboard.
    • Set antenna aside.
  11. Azpen A701 Motherboard Replacement: 步骤 11 中的图像 1,1
    • Gently remove motherboard from device.
  12. Azpen A701 Motherboard Replacement: 步骤 12 中的图像 1,1
    • Insert new motherboard.
    • Replace all three 2cm screws at the bottom of the motherboard.
结论
Michael
于03/11/15注册
568 声望
创作了4篇指南
团队
Colorado Springs, Team 2-1, Panko Spring 2015 Colorado Springs, Team 2-1, Panko Spring 2015 的会员
UCCS-PANKO-S15S2G1
3 名成员
创作了12篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 6
总计 331
