跳转到主内容
Azpen A701 Charger Port Replacement
你所需要的
  1. Azpen A701 Charger Port  Replacement, General Disassembly Prerequisite Guide: 步骤 1 中的图像 1,1
    • Remove the two 2cm screws on the bottom using the PH0 Phillips head screw driver.
  2. Azpen A701 Charger Port  Replacement: 步骤 2 中的图像 1,2 Azpen A701 Charger Port  Replacement: 步骤 2 中的图像 2,2
    • Pry open back piece with plastic spudger.
    • Remove the back piece of the device.
    • The back panel may be difficult to pry off, use gentle force.
  3. Azpen A701 Charger Port  Replacement: 步骤 3 中的图像 1,1
    • Disconnect speaker (which is attached by black and red wires) from back piece using plastic spudger.
  4. Azpen A701 Charger Port  Replacement: 步骤 4 中的图像 1,1
    • Gently pry the battery off of the device with the plastic spudger.
    • There is a large amount of glue holding the battery to the device.
    • Do not puncture the battery with the plastic spudger.
  5. Azpen A701 Charger Port  Replacement, Charger Port: 步骤 5 中的图像 1,1
    • The charger port is located on the underside of the motherboard (as pictured).
  6. Azpen A701 Charger Port  Replacement: 步骤 6 中的图像 1,1
    在这个步骤中使用的工具:
    购买
    • Remove the charger port by using tweezers and gently pulling.
  7. Azpen A701 Charger Port  Replacement: 步骤 7 中的图像 1,1
    • Solder and place new charger port.
结论
To reassemble your device, snap back piece on to the front piece and screw in both 2cm screws at the bottom.
Michael
于03/11/15注册
568 声望
创作了4篇指南
团队
Colorado Springs, Team 2-1, Panko Spring 2015 Colorado Springs, Team 2-1, Panko Spring 2015 的会员
UCCS-PANKO-S15S2G1
3 名成员
创作了12篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 9
总计 587
