跳转到主内容
Autosampler Programming (For Old & New Versions)
你所需要的
  1. Autosampler Programming  (For Old & New Versions), Turn on battery and autosampler: 步骤 1 中的图像 1,2 Autosampler Programming  (For Old & New Versions), Turn on battery and autosampler: 步骤 1 中的图像 2,2
    • 1. Switch battery "ON".
    • 2. Autosampler: Push "ON" button.
    • It will say ...STANDBY...
  2. Autosampler Programming  (For Old & New Versions), Select Program Mode: 步骤 2 中的图像 1,2 Autosampler Programming  (For Old & New Versions), Select Program Mode: 步骤 2 中的图像 2,2
    • 3. Push "ENTER/PROGRAM" button to see the "[PROGRAM, CONFIGURE] SAMPLER" screen. Push “ENTER/PROGRAM” button to select "PROGRAM".
    • 4. This will bring up the "[TIME, FLOW] PACED SAMPLING" screen. Use arrow to select "FLOW" then push “ENTER/PROGRAM” button.
  3. Autosampler Programming  (For Old & New Versions), Set Number, Type, and Size of Samples: 步骤 3 中的图像 1,3 Autosampler Programming  (For Old & New Versions), Set Number, Type, and Size of Samples: 步骤 3 中的图像 2,3 Autosampler Programming  (For Old & New Versions), Set Number, Type, and Size of Samples: 步骤 3 中的图像 3,3
    • 5. New screen shows: "SAMPLE EVERY __ PULSES." Press 20. Then push the “ENTER/PROGRAM” button.
    • 6. New screen will read: "MULTIPLEX SAMPLES?" Use arrow to select "NO". Then push the “ENTER/PROGRAM” button.
    • 7. New screen will read: "SAMPLE VOLUMES OF "____" ML". Press 1000. Then push the “ENTER/PROGRAM” button.
  4. Autosampler Programming  (For Old & New Versions), Starting Sampling: 步骤 4 中的图像 1,3 Autosampler Programming  (For Old & New Versions), Starting Sampling: 步骤 4 中的图像 2,3 Autosampler Programming  (For Old & New Versions), Starting Sampling: 步骤 4 中的图像 3,3
    • 8. New screen will read: "ENTER START TIME?" Use arrow to select "NO". Then push the “ENTER/PROGRAM” button. New screen: "PROGRAMMING SEQUENCE COMPLETE...". Then screen will read: "PROGRAM HALTED".
    • 9. Push "START SAMPLING" button. Screen will read: "[START, RESUME] SAMPLING PROGRAM?" Push "ENTER/PROGRAM" button to "START". Then push "ENTER/PROGRAM" button again to "START SAMPLING AT BOTTLE 1".
    • 10. Then should see on screen: "START FLOW COUNT AT __:__" (time).
    • It will take some time before it starts sampling.
    • Eventually screen will show: " BOTTLE 1 AFTER 20 PULSES".
终点
另外一个人完成了本指南。
Brooke Mason
于05/29/19注册
2,928 声望
创作了17篇指南
团队
Open-Storm Open-Storm 的会员
Community
14 名成员
创作了24篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 9
总计 173
