跳转到主内容
Autosampler Configuration for Node Control (For Old & New Versions)
  1. Autosampler Configuration for Node Control  (For Old & New Versions), Starting the configuration process.: 步骤 1 中的图像 1,3 Autosampler Configuration for Node Control  (For Old & New Versions), Starting the configuration process.: 步骤 1 中的图像 2,3 Autosampler Configuration for Node Control  (For Old & New Versions), Starting the configuration process.: 步骤 1 中的图像 3,3
    • 1. Turn on the autosampler. Screen will read "...STANDBY..."
    • 2. Press "ENTER/PROGRAM" button. Use arrows to highlight "CONFIGURE". Press "ENTER/PROGRAM" button
    • This will allow you to use the arrows to shuffle through the different configuration options. To select the one you want, press the "ENTER/PROGRAM" button.
    • 3. Use arrows to find "EVENT MARK". Press the "ENTER/PROGRAM" button.
  2. Autosampler Configuration for Node Control  (For Old & New Versions), Configuring "event mark".: 步骤 2 中的图像 1,3 Autosampler Configuration for Node Control  (For Old & New Versions), Configuring "event mark".: 步骤 2 中的图像 2,3 Autosampler Configuration for Node Control  (For Old & New Versions), Configuring "event mark".: 步骤 2 中的图像 3,3
    • 4. Use arrow to select "CONTINUOUS SIGNAL". Press "ENTER/PROGRAM" button.
    • 5. Use arrow to select "PUMP CYCLE". Press "ENTER/PROGRAM" button.
    • It is critical this setting is configured in order for the sensor node to operate the autosampler!
    • 6. Use arrows to find "EXIT CONFIGURATION." Press "ENTER/PROGRAM" button. This will bring up the screen "...STANDBY...
终点
另外一个人完成了本指南。
Brooke Mason
于05/29/19注册
2,928 声望
创作了17篇指南
团队
Open-Storm Open-Storm 的会员
Community
14 名成员
创作了24篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 79
