跳转到主内容
加入维修社区 - 创建账户
Autosampler Configuration (For Old & New Versions)
  1. Autosampler Configuration  (For Old & New Versions), Starting the configuration process.: 步骤 1 中的图像 1,2 Autosampler Configuration  (For Old & New Versions), Starting the configuration process.: 步骤 1 中的图像 2,2
    • 1. Turn on the autosampler. Screen will read "...STANDBY..."
    • 2. Press "ENTER/PROGRAM" button. Use arrows to highlight "CONFIGURE". Press "ENTER/PROGRAM" button
    • This will allow you to use the arrows to shuffle through the different configuration options. To select the one you want, press the "ENTER/PROGRAM" button.
  2. Autosampler Configuration  (For Old & New Versions), Configuring "set clock".: 步骤 2 中的图像 1,1
    • The first option for configuring is "SET CLOCK"
    • 3. Press "ENTER/PROGRAM" to "SET CLOCK". Use the numeric keys to set the time and date. You can use the arrows to move. When finished. Press "ENTER/PROGRAM" button.
  3. Autosampler Configuration  (For Old & New Versions), Configuring "bottles and sizes".: 步骤 3 中的图像 1,1
    • 4. Press "ENTER/PROGRAM" to configure "BOTTLES AND SIZES".
    • Use arrows to select "PORTABLE" sampler. Press "ENTER/PROGRAM" to configure bottles and sizes.
    • Use arrows to select "24" botles. Press "ENTER/PROGRAM" button.
    • Use numeric keys to enter "1000" mL for the "BOTTLE VOLUME". Press "ENTER/PROGRAM" button.
  4. Autosampler Configuration  (For Old & New Versions), Configuring "suction line".: 步骤 4 中的图像 1,1
    • 5. Press "ENTER/PROGRAM" to configure "SUCTION LINE".
    • Use arrow to select "3/8" inch for "SUCTION LINE I.D." Press "ENTER/PROGRAM" button.
    • Use arrow to select "VINYL" for "SUCTION LINE" type. Press "ENTER/PROGRAM" button.
    • Use numeric keys to enter "25" feet for "SUCTION LINE LENGTH". Press "ENTER/PROGRAM" button.
    • The suction line length may change based on location and should be measured!
  5. Autosampler Configuration  (For Old & New Versions), Configuring "liquid detector".: 步骤 5 中的图像 1,1
    • 6. Press "ENTER/PROGRAM" button to configure "LIQUID DETECTOR".
    • Use arrows to select "ENABLE" "LIQUID DECTOR". Press "ENTER/PROGRAM" button.
    • Use numeric keys to enter "3" "RINSE CYCLES." Press "ENTER/PROGRAM" button.
    • Screen will read "ENTER HEAD MANUALLY?" Use arrows to select "NO". Press "ENTER/PROGRAM" button.
    • Screen will read "RETRY UP TO X TIMES WHEN SAMPLING?" Use numeric keys to enter "3". Press "ENTER/PROGRAM" button.
  6. Autosampler Configuration  (For Old & New Versions), Configuring "programming mode".: 步骤 6 中的图像 1,1
    • 7. Press "ENTER/PROGRAM" to configure "PROGRAMMING MODE".
    • Use arrows to select "BASIC" mode. Press "ENTER/PROGRAM" button.
  7. Autosampler Configuration  (For Old & New Versions), Configuring "calibrate sampler".: 步骤 7 中的图像 1,1
    • 8. Press "ENTER/PROGRAM" to configure "CALIBRATE SAMPLER".
    • Use arrows to select "DISABLE" "CALIBRATE SAMPLER". Press "ENTER/PROGRAM" button.
  8. Autosampler Configuration  (For Old & New Versions), Configuring "start time delay".: 步骤 8 中的图像 1,1
    • 9. Press "ENTER/PROGRAM" to configure "START TIME DELAY". Press "ENTER/PROGRAM" button.
    • Screen will read "X MINUTE DELAY TO START." Use numeric keys to enter "0" minutes. Press "ENTER/PROGRAM" button.
  9. Autosampler Configuration  (For Old & New Versions), Configuring "enabling pin".: 步骤 9 中的图像 1,1
    • 10. Press "ENTER/PROGRAM" to configure "ENABLE PIN". Press "ENTER/PROGRAM" button.
    • Use arrow to select "NO" for "MASTER/SLAVE MODE?" Press "ENTER/PROGRAM" button.
    • Use arrow to select "NO" for "SAMPLE UPON DISABLE?" Press "ENTER/PROGRAM" button.
    • Use arrow to select "NO" for "SAMPLE UPON ENABLE?" Press "ENTER/PROGRAM" button.
    • Use arrow to select "NO" for "RESET SAMPLE INTERVAL?" Press "ENTER/PROGRAM" button.
    • Use arrow to select "NO" for "INHIBIT COUNTDOWN?" Press "ENTER/PROGRAM" button.
  10. Autosampler Configuration  (For Old & New Versions), Configuring "event mark".: 步骤 10 中的图像 1,1
    • 11. Press "ENTER/PROGRAM" to configure "EVENT MARK". Press "ENTER/PROGRAM" button.
    • Use arrow to select "CONTINUOUS SIGNAL". Press "ENTER/PROGRAM" button.
    • Use arrow to select "PUMP CYCLE". Press "ENTER/PROGRAM" button.
    • It is critical this setting is configured in order for the sensor node to operate the autosampler!
  11. Autosampler Configuration  (For Old & New Versions), Configuring "purge counts".: 步骤 11 中的图像 1,1
    • 12. Press "ENTER/PROGRAM" to configure "PURGE COUNTS". Press "ENTER/PROGRAM" button.
    • Use numeric keys to enter "XX" for "PRE-SAMPLE COUNTS". Press "ENTER/PROGRAM" button.
    • Use numeric keys to enter "XX" for "POST-SAMPLE COUNTS". Press "ENTER/PROGRAM" button.
  12. Autosampler Configuration  (For Old & New Versions), Configuring "tubing life".: 步骤 12 中的图像 1,1
    • 12. Press "ENTER/PROGRAM" to configure "TUBING LIFE". Press "ENTER/PROGRAM" button.
    • Screen will read "X PUMP COUNTS, WARNING AT XXX000". Press "ENTER/PROGRAM" button.
    • Use arrows to select "NO" for "RESET PUMP COUNTER?". Press "ENTER/PROGRAM" button.
    • Use numeric keys to enter "XXX000" for "PUMP COUNTS TO WARNING". Press "ENTER/PROGRAM" button.
  13. Autosampler Configuration  (For Old & New Versions), Configuring "program lock".: 步骤 13 中的图像 1,1
    • 13. Press "ENTER/PROGRAM" to configure "PROGRAM LOCK". Press "ENTER/PROGRAM" button.
    • Use arrows to select "DISABLE" "PROGRAM LOCK". Press "ENTER/PROGRAM" button.
  14. Autosampler Configuration  (For Old & New Versions), Configuring "sampler ID".: 步骤 14 中的图像 1,1
    • 15. The next configuration option is "SAMPLER ID". Skip this configuration step by using the arrows.
  15. Autosampler Configuration  (For Old & New Versions), Configuring "run diagonostics".: 步骤 15 中的图像 1,1
    • 16. The next configuration option is "RUN DIAGNOSTICS". Skip this configuration step by using the arrows.
终点
2等其他人完成本指南。
Brooke Mason
于05/29/19注册
2,958 声望
创作了17篇指南
团队
Open-Storm Open-Storm 的会员
Community
14 名成员
创作了24篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 24
总计 352
