跳转到主内容
Audiovox CR8030iE5 Power Adapter Replacement
你所需要的
  1. Audiovox CR8030iE5 Power Adapter Replacement, Top-Casing: 步骤 1 中的图像 1,1
    • Turn the device upside down.
    • Apply constant pressure to the base of your Audiovox, while holding the plastic casing until the casing is completely removed.
  2. Audiovox CR8030iE5 Power Adapter Replacement: 步骤 2 中的图像 1,1
    • Remove the four screws from the base using a Phillips #1 screwdriver.
  3. Audiovox CR8030iE5 Power Adapter Replacement: 步骤 3 中的图像 1,1
    • Turn the device right-side up.
    • Gently pull the top panel off of the device.
  4. Audiovox CR8030iE5 Power Adapter Replacement: 步骤 4 中的图像 1,1
    • Using a Phillips #1 screwdriver, remove the screw found in the middle of the board.
  5. Audiovox CR8030iE5 Power Adapter Replacement: 步骤 5 中的图像 1,1
    • Pull back the board gently to avoid disconnecting the attached wires.
    • This allows you to view the soldered connections on the other side, and the internal components.
  6. Audiovox CR8030iE5 Power Adapter Replacement, Power Adapter: 步骤 6 中的图像 1,1
    • One by one, de-solder the two wires that connect the power adapter to your Audiovox.
    • If you don't know how to solder, check out 如何焊接和拆焊.
    • Soldering irons are extremely hot and can burn you if you touch them!
    • If you hold the soldering iron tip at the same spot for too long, it can strip the metal from the plastic board. You may not be able to solder wire to that point again.
  7. Audiovox CR8030iE5 Power Adapter Replacement: 步骤 7 中的图像 1,1
    • Insert the wires of the new adapter into the designated holes and solder them into place.
结论
Savannah Smith
于04/18/13注册
51 声望
创作了2篇指南
团队
Cal Poly, Team 10-39, Amido Spring 2013 Cal Poly, Team 10-39, Amido Spring 2013 的会员
CPSU-AMIDO-S13S10G39
4 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 5
总计 413
