简介
If the docking port seems defective...install a new one! This guide shows you how to change out an old docking port that may not be working right.
Note: This guide involves soldering and should not be done by children. If you do not know how to solder, check out 如何焊接和拆焊 to learn how before beginning this guide.
你所需要的
Turn the device upside down.
Apply constant pressure to the base of your Audiovox, while holding the plastic casing until the casing is completely removed.
One by one, de-solder the line of nine wires attached to the docking port board. After pulling out the wires, save them. This is done so that you can solder them into the new docking port board.
另外一个人完成了本指南。
