跳转到主内容
Audio Technica ATH-AD500 Right Headphone Cable Replacement
你所需要的
  1. Audio Technica ATH-AD500 Right Headphone Cable Replacement, Speaker Assembly: 步骤 1 中的图像 1,1
    • Remove the ear pads by peeling them away from the grill.
  2. Audio Technica ATH-AD500 Right Headphone Cable Replacement: 步骤 2 中的图像 1,1
    • Remove all four 1cm screws on the inside of the headphone using a #1 Phillips head.
  3. Audio Technica ATH-AD500 Right Headphone Cable Replacement: 步骤 3 中的图像 1,1
    • Remove the speaker from the grill by pulling it out.
    • Remove the speaker carefully so you do not rip the wires out.
  4. Audio Technica ATH-AD500 Right Headphone Cable Replacement, Right Headphone Cable: 步骤 4 中的图像 1,2 Audio Technica ATH-AD500 Right Headphone Cable Replacement, Right Headphone Cable: 步骤 4 中的图像 2,2
    • Remove the wires by de-soldering both the red and yellow wires using the soldering iron and desoldering wick. If you need assistance, reference 如何焊接和拆焊.
    • The areas where you soldered will be hot so let the soldered joints cool for before handling again.
  5. Audio Technica ATH-AD500 Right Headphone Cable Replacement: 步骤 5 中的图像 1,2 Audio Technica ATH-AD500 Right Headphone Cable Replacement: 步骤 5 中的图像 2,2
    • Connect the the new red and yellow wires by re-soldering the wires using the soldering iron. If you need assistance, reference 如何焊接和拆焊.
结论
3等其他人完成本指南。
Melanie Reis
于01/11/13注册
227 声望
创作了5篇指南
团队
Cal Poly, Team 17-19, Forte Winter 2013 Cal Poly, Team 17-19, Forte Winter 2013 的会员
CPSU-FORTE-W13S17G19
6 名成员
创作了17篇指南
3条评论
Where can i buy a replacement cable? Cant seem to find it anywhere.
Stefan Rasmussen - 回复
Way late, but I would second information about finding a replacement cable.
Mateo Gomez - 回复
Hey guys, if any of you managed to find the correct cable I would like to know :) I want to fix my A900Xs
Erez Dahan - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 17
总计 4,465
