跳转到主内容
Audio Technica ATH-AD500 Left Headphone Cable Replacement
你所需要的
  1. Audio Technica ATH-AD500 Left Headphone Cable Replacement, Speaker Assembly: 步骤 1 中的图像 1,1
    • Remove the ear pads by peeling them away from the grill.
    My jbl waerless headphone speaker changes how price
    Max Mad - 回复
    How to install the earpads
    rangaranju - 回复
  2. Audio Technica ATH-AD500 Left Headphone Cable Replacement: 步骤 2 中的图像 1,1
    • Remove all four 1cm screws on the inside of the headphone using a #1 Phillips head.
  3. Audio Technica ATH-AD500 Left Headphone Cable Replacement: 步骤 3 中的图像 1,1
    • Remove the speaker from the grill by pulling it out.
    • Remove the speaker carefully so you do not rip the wires out.
  4. Audio Technica ATH-AD500 Left Headphone Cable Replacement, Left Headphone Cable: 步骤 4 中的图像 1,3 Audio Technica ATH-AD500 Left Headphone Cable Replacement, Left Headphone Cable: 步骤 4 中的图像 2,3 Audio Technica ATH-AD500 Left Headphone Cable Replacement, Left Headphone Cable: 步骤 4 中的图像 3,3
    • Desolder the red, yellow, and blue wires using a soldering iron and desoldering wick. If you need assistance, reference 如何焊接和拆焊.
    • The areas where you desolder will be hot so wait until the desoldered joints are cool before handling the wires again.
  5. Audio Technica ATH-AD500 Left Headphone Cable Replacement: 步骤 5 中的图像 1,2 Audio Technica ATH-AD500 Left Headphone Cable Replacement: 步骤 5 中的图像 2,2
    • Untie the knot in the thick main cable.
    • Remove the main cable from the headphones by pulling it out.
    • Thread the replacement cable into the hole on the bottom of the headphones. Pull the cable all the way through.
    “Thread the replacement cable into the hole on the bottom of the headphones“ what replacement cables?
    John S - 回复
    Hey, read my comment on the bottom of the guide if it’s still relevant to you.
    Erez Dahan -
    I have the same question, what replacement cable do I need?
    Erez Dahan - 回复
  6. Audio Technica ATH-AD500 Left Headphone Cable Replacement: 步骤 6 中的图像 1,3 Audio Technica ATH-AD500 Left Headphone Cable Replacement: 步骤 6 中的图像 2,3 Audio Technica ATH-AD500 Left Headphone Cable Replacement: 步骤 6 中的图像 3,3
    • Re-solder the new red, yellow, and blue wires using a soldering iron. If you need assistance, reference 如何焊接和拆焊.
    • The areas where you solder will be hot so wait until the solder joints are cool before handling the wires again.
结论
3等其他人完成本指南。
Melanie Reis
于01/11/13注册
227 声望
创作了5篇指南
团队
Cal Poly, Team 17-19, Forte Winter 2013 Cal Poly, Team 17-19, Forte Winter 2013 的会员
CPSU-FORTE-W13S17G19
6 名成员
创作了17篇指南
2条评论
Thank you so much! your guide helped me repair my AD900x!
Anwar X - 回复
Not sure if it’s on purpose or not but on my A900Xs the cable is on the left headphone and so, the one on the right is the one with the tiny wire going through, I found that a 2 core wire is needed for this replacement, I only managed to find one that’s 1,4mm diameter and it seems to be a little thicker than what’s actually inside the headphones but I figured I’ll give it a try, anyways here’s the wire I found on AliExpress https://www.aliexpress.com/item/40004436...
Erez Dahan - 回复
添加评论
浏览统计数据:
过去 24 小时: 5
过去 7 天: 15
过去 30 天: 53
总计 9,646
