跳转到主内容
Atari Lynx Backlight Replacement
你所需要的
  1. Atari Lynx Backlight Replacement, Atari Lynx: 步骤 1 中的图像 1,1
    • Before disassembling your Atari Lynx, be sure the device is powered off.
    • Remove any game in the console by opening the right latch and sliding the game to the right.
  2. Atari Lynx Backlight Replacement: 步骤 2 中的图像 1,1
    • Remove the four 35 mm Phillips #1 screws at each corner of the backside on the Atari Lynx.
    • Pinch the rear panel with your fingers and lift away from the Atari.
  3. Atari Lynx Backlight Replacement: 步骤 3 中的图像 1,1
    • Remove the battery panel by pinching the sides with your fingers and lifting it away from the Atari.
    • Be sure not to tear any wires attached to battery panel.
  4. Atari Lynx Backlight Replacement: 步骤 4 中的图像 1,1
    • Remove the control panel by pinching the sides with your fingers and lifting it away from the Atari.
    • Be sure not to tear the speaker wire while removing the control panel.
  5. Atari Lynx Backlight Replacement, Backlight: 步骤 5 中的图像 1,1
    • Pull out the logic-board.
    • Pull to the sides the four rubber tabs holding in the screen
  6. Atari Lynx Backlight Replacement: 步骤 6 中的图像 1,1
    • Unscrew the two 10 mm screws as shown with a Phillips #0 screwdriver in order to remove the shield behind the backlight.
  7. Atari Lynx Backlight Replacement: 步骤 7 中的图像 1,1
    • Flip over the motherboard and remove the shield behind the backlight.
  8. Atari Lynx Backlight Replacement: 步骤 8 中的图像 1,2 Atari Lynx Backlight Replacement: 步骤 8 中的图像 2,2
    • Flip the motherboard back over and desolder the two components that are holding the backlight in place.
    • If you need help with basic desoldering, click here.
结论
3等其他人完成本指南。
John Lopez
于01/27/14注册
443 声望
创作了4篇指南
团队
Cal Poly, Team 1-42, Maness Winter 2014 Cal Poly, Team 1-42, Maness Winter 2014 的会员
CPSU-MANESS-W14S1G42
5 名成员
创作了16篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 30
总计 4,454
