当前版本的文档还未经巡查,您可以查看最新的已查核版本。
Using the screwdriver and the PH1 bit, unscrew the five 10.0 mm screws on the bottom of the console.
One screw is under the main sticker in the middle of the console.
Unscrew the two 10.0 mm Phillips #1 screws, and gently pull back the green circuit board.
Remove gently. The circuit board is connected by wire to the board. Removing the cable from the console case may allow more slack.
The button springs may be under compression.
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
预览
