跳转到主内容
Asus Zenfone 3 Max Battery Replacement
你所需要的
  1. Asus Zenfone 3 Max Battery Replacement, Back cover: 步骤 1 中的图像 1,2 Asus Zenfone 3 Max Battery Replacement, Back cover: 步骤 1 中的图像 2,2
    • Using an iFixit opening tool, gently wedge the tool between the phone and the back casing.
    • Move the opening tool up and down to pry the back off of the device.
  2. Asus Zenfone 3 Max Battery Replacement: 步骤 2 中的图像 1,1
    • Once the original cover has been removed, apply the new cover to the back of the phone with careful pressure.
  3. Asus Zenfone 3 Max Battery Replacement, Battery: 步骤 3 中的图像 1,3 Asus Zenfone 3 Max Battery Replacement, Battery: 步骤 3 中的图像 2,3 Asus Zenfone 3 Max Battery Replacement, Battery: 步骤 3 中的图像 3,3
    • Gently disconnect the gold connection cable indicated by the red circle in the corresponding picture.
    • Pull back on the black adhesive tab that is adhered to the top of the battery. Tab removal is marked in the corresponding picture with a orange circle.
    • Once the gold connection cable and black adhesive tab are no longer connected to the battery, the battery can be removed.
  4. Asus Zenfone 3 Max Battery Replacement: 步骤 4 中的图像 1,3 Asus Zenfone 3 Max Battery Replacement: 步骤 4 中的图像 2,3 Asus Zenfone 3 Max Battery Replacement: 步骤 4 中的图像 3,3
    • Next, remove the battery by gently pulling on the blue removal tab located at the bottom of the device battery.
    • Completely remove existing device battery.
结论
另外一个人完成了本指南。
3条评论
I need to replace asus zenfone 3 max whole body lcd & what ever the requirements i want to know that it can be replaced or it is dead
Hassan Shahzad - 回复
Part not available on amazon & please bring your store to India, as the market is flooded with a ton of counterfeited products.
Deepank Malhotra - 回复
Asus Zenfone max 3, 5.5 এর ব্র্যাক সেল ও চার্জিং লজিক পাওয়া যাবে কি, জানাবেন প্লিজ
mafijur1122 - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 42
总计 3,123
