跳转到主内容
Asus Zenbook UX550GE-XB71T Battery Replacement
你所需要的
  1. Asus Zenbook UX550GE-XB71T Battery Replacement, Battery: 步骤 1 中的图像 1,2 Asus Zenbook UX550GE-XB71T Battery Replacement, Battery: 步骤 1 中的图像 2,2
    • Turn computer off and disconnect it from power.
    • Flip it over so the backside is facing you.
  2. Asus Zenbook UX550GE-XB71T Battery Replacement: 步骤 2 中的图像 1,2 Asus Zenbook UX550GE-XB71T Battery Replacement: 步骤 2 中的图像 2,2
    • Using the T5 Torx screwdriver, remove the ten screws under the computer.
    • Gently remove the back cover from the device.
  3. Asus Zenbook UX550GE-XB71T Battery Replacement: 步骤 3 中的图像 1,1
    • Using the Phillips #00 screwdriver, remove the four screws along the battery.
  4. Asus Zenbook UX550GE-XB71T Battery Replacement: 步骤 4 中的图像 1,3 Asus Zenbook UX550GE-XB71T Battery Replacement: 步骤 4 中的图像 2,3 Asus Zenbook UX550GE-XB71T Battery Replacement: 步骤 4 中的图像 3,3
    • Disconnect the ribbon cable by pushing upwards on the ZIF connector.
  5. Asus Zenbook UX550GE-XB71T Battery Replacement: 步骤 5 中的图像 1,1
    • Disconnect and remove the battery from the device.
结论
For optimal performance, after completing this guide, calibrate your newly installed battery.
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 12
过去 30 天: 36
总计 1,086
