跳转到主内容
Asus ZenFone 3 Zoom Screen Replacement
你所需要的
  1. Asus ZenFone 3 Zoom Screen Replacement, Screen Replacement: 步骤 1 中的图像 1,2 Asus ZenFone 3 Zoom Screen Replacement, Screen Replacement: 步骤 1 中的图像 2,2
    • Use sim card attachment for the screwdriver found in the IFIXIT box to remove the sim card tray from the phone.
  2. Asus ZenFone 3 Zoom Screen Replacement: 步骤 2 中的图像 1,1
    • Remove the 3.5 mm screws on both sides of the charging port, at the bottom of the phone, using the T2 screwdriver.
  3. Asus ZenFone 3 Zoom Screen Replacement: 步骤 3 中的图像 1,2 Asus ZenFone 3 Zoom Screen Replacement: 步骤 3 中的图像 2,2
    • Use the opening tool to separate the screen and the plastic body of the phone.
  4. Asus ZenFone 3 Zoom Screen Replacement: 步骤 4 中的图像 1,1
    • Utilize the PH #00 attachment to remove the two 3.3 mm screws in the bracket to the top left of the battery.
  5. Asus ZenFone 3 Zoom Screen Replacement: 步骤 5 中的图像 1,1
    • After removing the bracket and screws, pull up on the battery from the bottom of the unit and set aside.
  6. Asus ZenFone 3 Zoom Screen Replacement: 步骤 6 中的图像 1,2 Asus ZenFone 3 Zoom Screen Replacement: 步骤 6 中的图像 2,2
    • Remove all three screws near the top of the phone with the PH #00.
    • The top right and left screws are 3.25 mm.
    • The middle screw is 2.65 mm.
  7. Asus ZenFone 3 Zoom Screen Replacement: 步骤 7 中的图像 1,1
    • De-solder the single black speaker wire attached on the left side of the phone.
  8. Asus ZenFone 3 Zoom Screen Replacement: 步骤 8 中的图像 1,2 Asus ZenFone 3 Zoom Screen Replacement: 步骤 8 中的图像 2,2
    • Use the flat-edge side of iFixIt plastic spudger to detach both of the ribbon cables off of the motherboard at their connection point.
  9. Asus ZenFone 3 Zoom Screen Replacement: 步骤 9 中的图像 1,2 Asus ZenFone 3 Zoom Screen Replacement: 步骤 9 中的图像 2,2
    在这个步骤中使用的工具:
    购买
    • Use the tweezers to lift up on the edges of the motherboard located above where the battery was, then remove the motherboard.
  10. Asus ZenFone 3 Zoom Screen Replacement: 步骤 10 中的图像 1,2 Asus ZenFone 3 Zoom Screen Replacement: 步骤 10 中的图像 2,2
    • Remove the speaker cover at the bottom of the casing by taking out all five 3.25 mm screws with the PH #00.
  11. Asus ZenFone 3 Zoom Screen Replacement: 步骤 11 中的图像 1,1
    • Gently pry off the ribbon cable from speaker housing with the flat-edge side of the iFixit plastic spudger.
  12. Asus ZenFone 3 Zoom Screen Replacement: 步骤 12 中的图像 1,1
    • Remove the speaker once exposed.
  13. Asus ZenFone 3 Zoom Screen Replacement: 步骤 13 中的图像 1,1
    • Use iOpener to soften the adhesive keeping the screen on the device.
  14. Asus ZenFone 3 Zoom Screen Replacement: 步骤 14 中的图像 1,1
    • Pry off the screen beginning at the right-hand side toward the bottom of the phone with the plastic flat-edge spudger.
  15. Asus ZenFone 3 Zoom Screen Replacement: 步骤 15 中的图像 1,1
    • Progress around the perimeter of the phone with the pry tool till the screen is off.
  16. Asus ZenFone 3 Zoom Screen Replacement: 步骤 16 中的图像 1,2 Asus ZenFone 3 Zoom Screen Replacement: 步骤 16 中的图像 2,2
    • Remove the screen by pulling the attached ribbon cable out through the exposed opening.
  17. Asus ZenFone 3 Zoom Screen Replacement: 步骤 17 中的图像 1,1
    • The finished product will be a screen with nothing attached to the body of the phone.
终点
另外一个人完成了本指南。
Luke Theiss
于07/10/19注册
271 声望
撰写一个指南
团队
IUPUI, Team S2-G3, Harley Summer 2019 IUPUI, Team S2-G3, Harley Summer 2019 的会员
IUPUI-HARLEY-SU19S2G3
4 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 13
总计 2,475
