简介
This guide will show you how to replace the motherboard on an Asus ZenBook UX303U laptop.
你所需要的
Remove the eleven 4 mm Phillips #00 screws from the back panel.
These screws on other models are Torx T5 or T6, not Phillips
T4 screws on all but the two under the rear rubber feet; those are Phillips PH0 (and my model had two square rubber feet).
Pull the speaker cable out of its four retaining clips with either your fingers, or a plastic opening tool.
Remove the speakers from the old battery.
This was a bit more fiddly than expected given the speaker arms are stuck to the battery
Disconnect the display cable from the motherboard with a plastic opening tool.
4等其他人完成本指南。
一条评论
The bottom of the pictured device may feature Phillips #00 screws, but I also have this laptop and the screws around the edge of the bottom panel are Torx T5s on my device.
The process took me about 30 minutes. If I were to have to do it again then I could probably do it in 10 minutes now that I know what is involved!
Jon Kerridge - 回复
