跳转到主内容
Asus ZenBook UX303U Motherboard Fan Replacement
你所需要的
  1. Asus ZenBook UX303U Motherboard Fan Replacement, Back Panel: 步骤 1 中的图像 1,1
    • Remove the two round rubber feet at the hinge-edge of the laptop.
    The process took me about 30 minutes. If I were to have to do it again then I could probably do it in 10 minutes now that I know what is involved!
    Jon Kerridge - 回复
  2. Asus ZenBook UX303U Motherboard Fan Replacement: 步骤 2 中的图像 1,1
    • Remove the eleven 4 mm Phillips #00 screws from the back panel.
    These screws on other models are Torx T5 or T6, not Phillips
    Dylan Warburg - 回复
    T4 screws on all but the two under the rear rubber feet; those are Phillips PH0 (and my model had two square rubber feet).
    Gregg Stanley - 回复
  3. Asus ZenBook UX303U Motherboard Fan Replacement: 步骤 3 中的图像 1,2 Asus ZenBook UX303U Motherboard Fan Replacement: 步骤 3 中的图像 2,2
    • Using a plastic opening tool pry the back panel off of the laptop.
    I lift more than the last photo shows. Dark rubber with plots, visible on photo are blocking the opening.
    djibe - 回复
  4. Asus ZenBook UX303U Motherboard Fan Replacement, Battery: 步骤 4 中的图像 1,2 Asus ZenBook UX303U Motherboard Fan Replacement, Battery: 步骤 4 中的图像 2,2
    • Pull the speaker cable out of its four retaining clips with either your fingers, or a plastic opening tool.
    Skip this step on UX430U
    Styyvii - 回复
  5. Asus ZenBook UX303U Motherboard Fan Replacement: 步骤 5 中的图像 1,2 Asus ZenBook UX303U Motherboard Fan Replacement: 步骤 5 中的图像 2,2
    • Remove all seven 2 mm Phillips #00 screws from the battery.
  6. Asus ZenBook UX303U Motherboard Fan Replacement: 步骤 6 中的图像 1,2 Asus ZenBook UX303U Motherboard Fan Replacement: 步骤 6 中的图像 2,2
    • Pull the speaker connector toward the edge of the laptop to disconnect it from its socket.
    Skip this step on UX430U also
    Styyvii - 回复
  7. Asus ZenBook UX303U Motherboard Fan Replacement: 步骤 7 中的图像 1,2 Asus ZenBook UX303U Motherboard Fan Replacement: 步骤 7 中的图像 2,2
    • Lift the battery connector straight up off its socket to disconnect it from the motherboard.
    • Do not pry on the socket itself or you risk damaging the motherboard.
  8. Asus ZenBook UX303U Motherboard Fan Replacement: 步骤 8 中的图像 1,2 Asus ZenBook UX303U Motherboard Fan Replacement: 步骤 8 中的图像 2,2
    • Lift the battery and speakers up and pull out to remove.
    • Check underneath the battery for the wire assembly connecting the touchpad to the motherboard. This connection may stick to the underside of the battery. Be careful not to damage it when removing the battery.
  9. Asus ZenBook UX303U Motherboard Fan Replacement: 步骤 9 中的图像 1,1
    • Remove the speakers from the old battery.
    This was a bit more fiddly than expected given the speaker arms are stuck to the battery
    Jon Kerridge - 回复
  10. Asus ZenBook UX303U Motherboard Fan Replacement, Motherboard fan: 步骤 10 中的图像 1,2 Asus ZenBook UX303U Motherboard Fan Replacement, Motherboard fan: 步骤 10 中的图像 2,2
    • Disconnect the display cable from the motherboard with a plastic opening tool.
  11. Asus ZenBook UX303U Motherboard Fan Replacement: 步骤 11 中的图像 1,2 Asus ZenBook UX303U Motherboard Fan Replacement: 步骤 11 中的图像 2,2
    • Remove the three 6mm Phillips #00 screws from the hinge.
    • Remove the 2mm Phillips #00 screw from the plastic housing securing the fan into place.
  12. Asus ZenBook UX303U Motherboard Fan Replacement: 步骤 12 中的图像 1,2 Asus ZenBook UX303U Motherboard Fan Replacement: 步骤 12 中的图像 2,2
    • Lift the bottom of the laptop up slightly in order to unhinge the laptop.
    • Lift the screen assembly hinge up and off of the motherboard fan.
  13. Asus ZenBook UX303U Motherboard Fan Replacement: 步骤 13 中的图像 1,3 Asus ZenBook UX303U Motherboard Fan Replacement: 步骤 13 中的图像 2,3 Asus ZenBook UX303U Motherboard Fan Replacement: 步骤 13 中的图像 3,3
    • Using tweezers, disconnect the cable connector from the motherboard fan.
  14. Asus ZenBook UX303U Motherboard Fan Replacement: 步骤 14 中的图像 1,2 Asus ZenBook UX303U Motherboard Fan Replacement: 步骤 14 中的图像 2,2
    • Lift the fan up and off of the white pegs that secure it into place.
结论
另外一个人完成了本指南。
Luis Perez
于02/14/18注册
616 声望
创作了2篇指南
团队
USF Tampa, Team S3-G5, Nance Spring 2018 USF Tampa, Team S3-G5, Nance Spring 2018 的会员
USFT-NANCE-S18S3G5
3 名成员
创作了9篇指南
一条评论
The bottom of the pictured device may feature Phillips #00 screws, but I also have this laptop and the screws around the edge of the bottom panel are Torx T5s on my device.
Nick Brennan - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 12
总计 2,167
