跳转到主内容
Asus ZenBook UX303U Battery Replacement
你所需要的
  1. Asus ZenBook UX303U Battery Replacement, Back Panel: 步骤 1 中的图像 1,1
    • Remove the two round rubber feet at the hinge-edge of the laptop.
    The process took me about 30 minutes. If I were to have to do it again then I could probably do it in 10 minutes now that I know what is involved!
    Jon Kerridge - 回复
  2. Asus ZenBook UX303U Battery Replacement: 步骤 2 中的图像 1,1
    • Remove the eleven 4 mm Phillips #00 screws from the back panel.
    These screws on other models are Torx T5 or T6, not Phillips
    Dylan Warburg - 回复
    T4 screws on all but the two under the rear rubber feet; those are Phillips PH0 (and my model had two square rubber feet).
    Gregg Stanley - 回复
  3. Asus ZenBook UX303U Battery Replacement: 步骤 3 中的图像 1,2 Asus ZenBook UX303U Battery Replacement: 步骤 3 中的图像 2,2
    • Using a plastic opening tool pry the back panel off of the laptop.
    I lift more than the last photo shows. Dark rubber with plots, visible on photo are blocking the opening.
    djibe - 回复
  4. Asus ZenBook UX303U Battery Replacement, Battery: 步骤 4 中的图像 1,2 Asus ZenBook UX303U Battery Replacement, Battery: 步骤 4 中的图像 2,2
    • Pull the speaker cable out of its four retaining clips with either your fingers, or a plastic opening tool.
    Skip this step on UX430U
    Styyvii - 回复
  5. Asus ZenBook UX303U Battery Replacement: 步骤 5 中的图像 1,2 Asus ZenBook UX303U Battery Replacement: 步骤 5 中的图像 2,2
    • Remove all seven 2 mm Phillips #00 screws from the battery.
  6. Asus ZenBook UX303U Battery Replacement: 步骤 6 中的图像 1,2 Asus ZenBook UX303U Battery Replacement: 步骤 6 中的图像 2,2
    • Pull the speaker connector toward the edge of the laptop to disconnect it from its socket.
    Skip this step on UX430U also
    Styyvii - 回复
  7. Asus ZenBook UX303U Battery Replacement: 步骤 7 中的图像 1,2 Asus ZenBook UX303U Battery Replacement: 步骤 7 中的图像 2,2
    • Lift the battery connector straight up off its socket to disconnect it from the motherboard.
    • Do not pry on the socket itself or you risk damaging the motherboard.
  8. Asus ZenBook UX303U Battery Replacement: 步骤 8 中的图像 1,2 Asus ZenBook UX303U Battery Replacement: 步骤 8 中的图像 2,2
    • Lift the battery and speakers up and pull out to remove.
    • Check underneath the battery for the wire assembly connecting the touchpad to the motherboard. This connection may stick to the underside of the battery. Be careful not to damage it when removing the battery.
  9. Asus ZenBook UX303U Battery Replacement: 步骤 9 中的图像 1,1
    • Remove the speakers from the old battery.
    This was a bit more fiddly than expected given the speaker arms are stuck to the battery
    Jon Kerridge - 回复
结论
16等其他人完成本指南。
Dean Anderson
于02/14/18注册
621 声望
创作了3篇指南
团队
USF Tampa, Team S3-G5, Nance Spring 2018 USF Tampa, Team S3-G5, Nance Spring 2018 的会员
USFT-NANCE-S18S3G5
3 名成员
创作了9篇指南
11条评论
hello where I can buy a UX303U battery for asus?
jeannette dreifus - 回复
hello! Where I can buy a UX303U battery for my Asus netbook?
thanks
There are two screws holding the back panel in place. They are located below the two rubber pads at the back of the pc. They must be removed in order to open the back panel.
Dave Man - 回复
Just gone through this, but two problems surfaced. 1 it won’t connect to our usual WiFi router and can’t figure out why. Is it possible to damage the WiFi connectivity when removing battery? 2 there’s no indication of charge levels. It says 100% and doesn’t change. Thoughts?
Barny Harper - 回复
Take all that back. Went back in and battery connector hadn’t clicked in far enough. Seems to be working fine now.
Barny Harper - 回复
The bottom of the pictured device may feature Phillips #00 screws, but I also have this laptop and the screws around the edge of the bottom panel are Torx T5s on my device.
Nick Brennan - 回复
Same here, they are really small Torx on my Asus UX303U!
Dave Taylor -
Can I use this laptop without a battery?
m khn - 回复
Installation was simple, but took me longer than as described. That was due to battery I purchased from iFixit had a longer power cable than original. This required me to angle the power cable in first and secure the battery before finally being able to secure the cable to the socket. Other than that, it worked out.
Jorge Camacho - 回复
Good steps and pictures, thx. Tool kit nice, w. the top tray for keeping sorting screws.
Also useful:
[Notebook ASUS Battery Information Center | Official Support | ASUS USA|new_window=true]
Asus ZenBook UX303 disassembly and battery replace, как разобрать и поменять батарею ноутбука - YouTube
CHARLES SCHULZ - 回复
Where can I get replacement rubber feet?
Alan Fink - 回复
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 31
过去 30 天: 126
总计 30,427
