跳转到主内容
Asus Vivobook Q301LA-BHI5T02 Fan and Heatsink Replacement
你所需要的
  1. Asus Vivobook Q301LA-BHI5T02 Fan and Heatsink Replacement, Back Cover: 步骤 1 中的图像 1,1
    • Make sure the computer is turned off.
    • Flip the device over so that the back cover is facing you.
  2. Asus Vivobook Q301LA-BHI5T02 Fan and Heatsink Replacement: 步骤 2 中的图像 1,2 Asus Vivobook Q301LA-BHI5T02 Fan and Heatsink Replacement: 步骤 2 中的图像 2,2
    • Remove the four 5mm Phillips #1 screws from the top of the laptop.
    • Remove the two 6mm Phillips #1 screws from the sides of the laptop.
    • Remove the four 2mm Phillips #1 screws from the bottom of the laptop.
  3. Asus Vivobook Q301LA-BHI5T02 Fan and Heatsink Replacement: 步骤 3 中的图像 1,3 Asus Vivobook Q301LA-BHI5T02 Fan and Heatsink Replacement: 步骤 3 中的图像 2,3 Asus Vivobook Q301LA-BHI5T02 Fan and Heatsink Replacement: 步骤 3 中的图像 3,3
    • Use a plastic opening tool to gently pry the bottom of the laptop up. Slowly slide it along the edges, twisting it every so often to pop the bottom of the laptop out of the clips holding it in place.
  4. Asus Vivobook Q301LA-BHI5T02 Fan and Heatsink Replacement: 步骤 4 中的图像 1,1
    • Lift off the cover and remove the back cover from the device.
  5. Asus Vivobook Q301LA-BHI5T02 Fan and Heatsink Replacement, Fan and Heatsink: 步骤 5 中的图像 1,3 Asus Vivobook Q301LA-BHI5T02 Fan and Heatsink Replacement, Fan and Heatsink: 步骤 5 中的图像 2,3 Asus Vivobook Q301LA-BHI5T02 Fan and Heatsink Replacement, Fan and Heatsink: 步骤 5 中的图像 3,3
    • Using a Phillips #1 Screwdriver remove the three 3 mm black screws and four 2 mm copper screws holding the fan and heat sink in place.
  6. Asus Vivobook Q301LA-BHI5T02 Fan and Heatsink Replacement: 步骤 6 中的图像 1,2 Asus Vivobook Q301LA-BHI5T02 Fan and Heatsink Replacement: 步骤 6 中的图像 2,2
    • Remove the wire connecting the fan to the motherboard.
  7. Asus Vivobook Q301LA-BHI5T02 Fan and Heatsink Replacement: 步骤 7 中的图像 1,2 Asus Vivobook Q301LA-BHI5T02 Fan and Heatsink Replacement: 步骤 7 中的图像 2,2
    • Gently remove the fan and heat sink from the motherboard.
    • On reassembly, be sure to clean the CPU and heat sink and reapply thermal compound to the CPU. Follow this guide to learn how.
结论
Royce Gunter
于10/02/17注册
101 声望
撰写一个指南
团队
USF Tampa, Team S10-G3, Thompson Fall 2017 USF Tampa, Team S10-G3, Thompson Fall 2017 的会员
USFT-THOMPSON-F17S10G3
4 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 4
过去 30 天: 13
总计 588
