跳转到主内容
Asus Vivobook Max X541SA-PD0703X Motherboard Replacement
你所需要的
  1. Asus Vivobook Max X541SA-PD0703X Motherboard Replacement, Hard Drive: 步骤 1 中的图像 1,1
    • Flip the laptop upside down so that the back of the laptop faces you.
  2. Asus Vivobook Max X541SA-PD0703X Motherboard Replacement: 步骤 2 中的图像 1,1
    • Remove the following ten Phillips #0 screws from the bottom of the laptop:
    • Six 13mm screws.
    • Four 11mm screws.
  3. Asus Vivobook Max X541SA-PD0703X Motherboard Replacement: 步骤 3 中的图像 1,3 Asus Vivobook Max X541SA-PD0703X Motherboard Replacement: 步骤 3 中的图像 2,3 Asus Vivobook Max X541SA-PD0703X Motherboard Replacement: 步骤 3 中的图像 3,3
    • Using a plastic opening tool, pry up the palm rest from the bottom case of the laptop.
    • Don't completely remove as there are ribbon cables connecting the two halves.
  4. Asus Vivobook Max X541SA-PD0703X Motherboard Replacement: 步骤 4 中的图像 1,3 Asus Vivobook Max X541SA-PD0703X Motherboard Replacement: 步骤 4 中的图像 2,3 Asus Vivobook Max X541SA-PD0703X Motherboard Replacement: 步骤 4 中的图像 3,3
    • Use a spudger to flip up the retaining flaps on both keyboard ribbon cable ZIF sockets.
    • Pull the ribbon cables out of their sockets.
  5. Asus Vivobook Max X541SA-PD0703X Motherboard Replacement: 步骤 5 中的图像 1,1
    • Remove the three 6mm Phillips #0 screws from the motherboard.
  6. Asus Vivobook Max X541SA-PD0703X Motherboard Replacement: 步骤 6 中的图像 1,2 Asus Vivobook Max X541SA-PD0703X Motherboard Replacement: 步骤 6 中的图像 2,2
    • Pull the Wi-Fi card out of the motherboard.
  7. Asus Vivobook Max X541SA-PD0703X Motherboard Replacement: 步骤 7 中的图像 1,1
    • Remove the hard drive by pulling it towards the right, and removing it from the laptop case
  8. Asus Vivobook Max X541SA-PD0703X Motherboard Replacement, Disc Drive: 步骤 8 中的图像 1,1
    • Remove the disc drive by sliding it towards the right and removing it from the laptop case
  9. Asus Vivobook Max X541SA-PD0703X Motherboard Replacement, Motherboard: 步骤 9 中的图像 1,2 Asus Vivobook Max X541SA-PD0703X Motherboard Replacement, Motherboard: 步骤 9 中的图像 2,2
    • Remove the three 6mm Phillips #0 screws from the fan shroud.
    • Remove the shroud from the motherboard.
  10. Asus Vivobook Max X541SA-PD0703X Motherboard Replacement: 步骤 10 中的图像 1,1
    • Pull the metal casing to the right.
    • Be careful when pulling the case because it may break the motherboard.
  11. Asus Vivobook Max X541SA-PD0703X Motherboard Replacement: 步骤 11 中的图像 1,2 Asus Vivobook Max X541SA-PD0703X Motherboard Replacement: 步骤 11 中的图像 2,2
    • There is a wire attached to the screen display.
    • Peel the sticker and disconnect it from the motherboard.
  12. Asus Vivobook Max X541SA-PD0703X Motherboard Replacement: 步骤 12 中的图像 1,1
    • Remove the plastic covering off of the motherboard.
  13. Asus Vivobook Max X541SA-PD0703X Motherboard Replacement: 步骤 13 中的图像 1,1
    • Remove the five 6mm Phillips #0 screws from the motherboard.
  14. Asus Vivobook Max X541SA-PD0703X Motherboard Replacement: 步骤 14 中的图像 1,2 Asus Vivobook Max X541SA-PD0703X Motherboard Replacement: 步骤 14 中的图像 2,2
    • Remove the cables connected to the motherboard by unplugging them using a plastic opening tool, or by hand.
  15. Asus Vivobook Max X541SA-PD0703X Motherboard Replacement: 步骤 15 中的图像 1,1
    • Pull the motherboard to the right and lift up.
结论
2等其他人完成本指南。
Hetvi Mehta
于02/22/18注册
781 声望
创作了5篇指南
团队
USF Tampa, Team S1-G4, Cagle Spring 2018 USF Tampa, Team S1-G4, Cagle Spring 2018 的会员
USFT-CAGLE-S18S1G4
4 名成员
创作了7篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 15
总计 3,108
