当前版本的文档还未经巡查,您可以查看最新的已查核版本。
这个步骤还没有翻译 帮忙翻译一下
Flip the device such that the labels are on top.
Use a Phillips #1 screwdriver to remove the four 8mm screws near the back.
Use the same screwdriver to remove the four 5mm screws in the front.
Use the same screwdriver to remove the single 9mm screw in the center.
Make sure that the device is powered down and unplugged.
Remove the back cover by gently prying with a spudger.
Remove the eight 5mm screws using a Phillips #1 screwdriver.
Do not puncture the battery.
Disconnect the battery ribbon cable from the motherboard.
Remove the battery from the laptop.
Unplug and remove the CMOS battery.
取消:我没有完成这个指南。
与4其他贡献者
于01/13/19注册
756 声望
创作了6篇指南
徽章: 10
+ 7更多徽章
EWU-CRAWFORD-W19S1G5
4 名成员
创作了7篇指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
过去 24 小时: 5
过去 7 天: 21
过去 30 天: 88
总计 6,377
